Civil 3D Forum
Can't move pipe network structure by grip
7 REPLIES 7
Message 1 of 8
smwagner
3383 Views, 7 Replies
I have a pipe network, all the structures and pipes are connected properly.  When I use the grip to move my structure, it will not move.  I have to move both pipes then the manhole to relocate my structure.  Shouldn't I be able to move the manhole and the pipes come with it?  Instead I am having to make 3 grip edits and then reconnect the structures and pipes.  Anyone run into this?  Using 2012.  Thanks in advance!
7 REPLIES 7
Message 2 of 8
jmayo-EE
in reply to: smwagner
That does sound odd.
Did you try to recover the file in a new session?
John Mayo
Message 3 of 8
smwagner
in reply to: jmayo-EE
Yes I did try that it still does not work.  I can place new structures and edit them as I please, but none of the current structures can be moved.  Trying to avoid replacing all of my manholes...
Message 4 of 8
nachziger13
I have had the same problem.  In my case if I used the command "-purge" and purged out the reg apps (R), it solved the problem.
Hope this helps!
Nate
Message 5 of 8
Joe-Bouza
Are you sure they are not DS in
Your Name
Message 6 of 8
kate
in reply to: Joe-Bouza
Set your view in model space to TOP would fix this problem.
Message 7 of 8
bene
in reply to: nachziger13
Purging Regapps worked for me
Message 8 of 8
nonbeard13
before moving the structure -
try connecting the parts first
right click on the pipe and click Connect fo Part
see if that helps
not sure why the pipes and manholes would not be connected originally ???
nonbeard13
Rail Community
