Civil 3D Forum
Can't get Pastel colors assigned to surface range
9 REPLIES 9
Message 1 of 10
Joe-Bouza
1097 Views, 9 Replies
I have a volume surface that I want cut & fill displayed with elevation banding. I created a surface style and chose pastels for the color scheme. When I analyze the surface I chose elevations>> range interval with datum and I get 2d solids but they are not pastel even though the style assigned is the one I mentioned.
How do I get the colors to be pastel?
Joe Bouza
9 REPLIES 9
Message 2 of 10
jmayo-EE
in reply to: Joe-Bouza
Did you recompute the surface analysis, i.e. add the ranges again?
John Mayo
Message 3 of 10
jmayo-EE
Can you post or send a file? I just did this and it worked fine in 2012.
John Mayo
Message 4 of 10
Joe-Bouza
in reply to: jmayo-EE
Thanks John. Its on the way
Joe Bouza
Message 5 of 10
KirkNoonan
What color scheme are you getting instead of the pastels? That might be the key to finding which style or setting is off.
Message 6 of 10
jmayo-EE
The elevation banding needs to be recomputed after seeing Joe's file.
In the Surface Properties dialog, Analysis tab, select Elevation Ranges, assign the number of desired ranges and then hit the chevron arrow to recompute/repopulate the computed slope ranges listed.
This is similar to the issue many of us had with label styles when we were learning C3D. We never hit the Arrow button to update the data.
John Mayo
Message 7 of 10
Joe-Bouza
pastels.PNGOk. I’m a bigger dope than I thought. I’ve repopulated that button at least a dozen times and never get pastels? I can’t find the chevron because I only have a down arrow.
Joe Bouza
Message 8 of 10
Joe-Bouza
in reply to: KirkNoonan
Thanks Kirk,
I posted images to JM
Joe Bouza
Message 9 of 10
jmayo-EE
With Kirk's recommendation and Joe's sleuthing we can see that users do not have the ability to edit the fields that need to be edited.
John Mayo
Message 10 of 10
Joe-Bouza
I'll open an SR on Monday.
Joe Bouza
Rail Community
