Every time I try to edit the Contents of a label on the Layout Tab of the Style Composer I get the errors below. I've tried a restart, a reboot, a repair and a reinstall with no change. This happens even in a new blank drawing.
Each of these messages appears and has to be closed about 5 times.
Any thoughts?
Allen
Allen Jessup
CAD Manager - Designer
Solved by ToddRogers-WPM. Go to Solution.
Possible .Net issue. Uninstall all versions of .net and re-install .Net 4.
Thanks for the quick response. I just talked to out IT dept and they didn't sound too thrilled with the idea. So I guess I'm not going to get to test it right now. The only .NET installed is 4 and I have updates through last Friday.
Allen
Allen Jessup
Have you logged in as a different user and tried it? If you log on as a different user and it works, then the secondary installer should be initiated. It means that your Windows profile is corrupt.
That seems to be it. I created a temporary account on my computer and from that I can edit the Contents of the Label Style. I can't create a new network account so I have to wait and see what IT can do for me.
Thank You.
Allen
Allen Jessup
If your settings will allow you, you can browse to C:\Users\[user name]\AppData\Local\Autodesk and delete the C3D 2012 folder, then delete the folder under C:\Users\[user name]\AppData\Roaming\Autodesk. Make sure Civil 3D is closed before doing this. Restart the program, and you should be good to go from there.
Allen Jessup
