Civil 3D Forum
Can't Edit Annotative text, move, rotate or erase
7 REPLIES 7
Message 1 of 8
68widetrack
4460 Views, 7 Replies
Created L200 Annotative text in C3d drawing w/ SP1, INSTALLED SP2,
working in dwg now I can not move, rotate or erase the text that is annotative (the two scale symbols) appear at every piece of text. I tried making in the STYLE text box toggling on and off "Annotative Text" does not help. Also did -purge Regapps, still can not edit text
7 REPLIES 7
Message 2 of 8
sboon
in reply to: 68widetrack
I've seen this one too. Try closing and reopening your drawing.
Steve
Expert Elite Alumnus
Message 3 of 8
68widetrack
I just tried that, still can't do simple text edits. I think I am going to save the dwg back to '07 acad and fix the text.
Message 4 of 8
Audit the drawing. Then you will be able to edit annotated text. It will
happen again and just re-audit. No need to close and reopen.
<68widetrack> wrote in message news:5763617@discussion.autodesk.com...
Message 5 of 8
68widetrack
THANKS ROBERT!!! THAT WORKED!!! I'll have to remember that one.
Message 6 of 8
JeffPaulsen
I am not sure about SP2 but in SP1 the thing that triggered this problem was a save or autosave. When you first open the drawing it works fine. After a save you can no longer edit annotative text until you audit the drawing.
Jeff Paulsen
Civil 3D 2020.4 | Win 10 Pro N 64-bit
Xeon W-2223 @ 3.60GHz, 32GB Ram | NVidia Quadro P2200
Message 7 of 8
Greg-CR
in reply to: JeffPaulsen
I just had the same error show up in Autocad 2012.
I was working on the file this morning no problems. This afternoon edit some text issue shows up. audit the file I can move the text rotate copy. As soon as I edit a string of text Autocad no longer lets me do anything with that string. I get an error object is already open if I try to change any properties in the properties dialog box.
Message 8 of 8
Discussion_Admin
in reply to: Greg-CR
Moved:
Rail Community
