I can't figure out how to reverse the flow direction on my pipe so I was going to just redraw it but after I delete a pipe and rt click to edit network the "add pipes and stuctures" won't let me add anything. I'm just guessing I need to reverse the flow direction because my invert out and invert in elevations are backwards in the profile. I'm working in Civil3D 2012.
One way the Flow Direction can be reversed is in "Pipe Properties" dialog>Pipe Flow Direction Method.
Flow direction is the problem. Did you try reversing the direction using MODIFY>Pipe Networks>Modify>Change Flow Direction? This is the correct way to reverse direction.
I see your problem now. Structures can label Invert Flow In and Invert Flow Out, and that IN-OUT direction is determined by the flow direction of your system (and modified using the Change Flow Direction command).
Pipes, however, do not recognize Flow In and Flow Out; they only recognize Start Elevation and End Elevation. Start and End are determined solely by the driection they are drawn initially and can only be changed (as far as I know) by swapping them end for end with grip edits, or deleting and redrawing them in the correct direction. This is why it is critically important to pay attention to the direction pipes are drawn when creating the network. The Edit Network toolbar has an icon showing the default start to end direction... pay attention to this when creating your pipes. This is especially crucial if using Spanning Pipes Labels, otherwise slopes will label incorrectly as well.
