Civil 3D Forum
Can't delete duplicate grading criteria
40 REPLIES 40
Message 1 of 41
gr8gonzo0
5059 Views, 40 Replies
For some reason my drawing had created several duplicates of my grading critera. For example, my drawing has the following critera:
Cut to Surface
Cut to Surface.1
Cut to Surface.2
Cut to Surface.3
Cut to Surface.4
I did not create all these criteria, they just appeared one day. The problem is that I can't seem to be able to delete the duplicate ones. I get an error saying that the criteria "is currently in use, so it can not be deleted". I have deleted all the grading in my file and I still get this error. I have tried RECOVER and AUDIT several times with no luck.
Any suggestions?
Thank you.
40 REPLIES 40
Message 41 of 41
busley7TUUJ
in reply to: ArchD
ArchD,
THANK YOU THANK YOU.  Like everyone else I was trying to clean up our company template and this was the last item giving me FITS.  Your solution worked perfect.  Only wish I found this post sooner
Rail Community
