Distinguished Contributor
pocketmerlin
Message 1 of 5 (821 Views)
Can't change rim elevation for a storm manhole
821 Views, 4 Replies
01-15-2014 12:31 PM
I have a storm manhole whose rim I can't set below a certain elevation...if I try to make it lower, it just reverts back to that number that it won't go lower than. I changed the properties so that the structure no longer has a reference surface, I changed the "Automatic Surface Adjustment" option for Insertion Rim Behavior to "False."
Can anyone help me figure out what's restricting my ability to adjust the rim height?
Jeff_M
Message 2 of 5 (816 Views)
Re: Can't change rim elevation for a storm manhole
01-15-2014 12:53 PM in reply to: pocketmerlin
You cannot force the rim below the elevation needed for any cone or slab on the structure. C3D will not allow a pipe to lie in that region, so change the structure to have a shorter cone/taper section.
Jay_B
Message 3 of 5 (808 Views)
01-15-2014 01:04 PM in reply to: pocketmerlin
To add to what Jeff said, it may be possible to adjust some settings in Structure Properties such as frame height
or barrel clearance depending on parts catalog etc. to make minor adjustments.
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
pocketmerlin
Message 4 of 5 (789 Views)
01-15-2014 02:30 PM in reply to: Jay_B
Frame height is as low as it can go from the three options given to me by the dropdown, and I am not able to edit barrel clearance--it's greyed out.
I assume I would have to make a new part in part builder in order to get a structure that will let me have a lower rim height then?
Joe-Bouza
Message 5 of 5 (771 Views)
01-15-2014 03:19 PM in reply to: pocketmerlin
Use a NF structure and display a block
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
