Civil 3D Forum
Can't browse to open file
31 REPLIES 31
Message 1 of 32
CountyUser
67429 Views, 31 Replies
When I open the software and try select "open", I have to type in the name of the drawing and path on the command line, it won't allow me to browse for the drawing or show recently used drawings.  I can work around this by typing in the path and name, but it is inconvenient.  Is there a setting that I need to change?
31 REPLIES 31
Message 2 of 32
OMCUSNR
in reply to: CountyUser
FILEDIA=1  I think (IIRC)?
Reid
Homebuilt box: I5-2500k, MSI P67A-GD65, 12gig DDR3 1600 ram, ASUS ENGTX460 Video card, WD Velociraptor WD4500HLHX HD, Win 7 64 pro.
Message 3 of 32
CountyUser
in reply to: OMCUSNR
That worked!  Thank you!
Message 4 of 32
falcon125
My computer just started doig that.
Where do I type  "FILEDIA=1" ?
Message 5 of 32
Neilw_05
in reply to: falcon125
Do you not have a command line? It may be you have turned it off but you should still be able to type commands. Press escape several times to cancel any active commands and then type FILEDIA and hit enter. Normally you would then see a prompt on the command line for inputting a value. If you can't see the command line just type the number one after hitting enter and you should then start getting the dialogues when opening files.
If you press Ctrl+9 it should restore your command line.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 6 of 32
antoniovinci
in reply to: Neilw_05
Since Autocad needs a path to open/save files, that means the command line is visible somewhere...
I concur with CTRL-9 or, even quicker, by pressing F2 to trigger the biggest text window.
Message 7 of 32
falcon125
Thanks. That worked.
Message 8 of 32
heidigoodrich
Thanks!
How do you learn this stuff?
Message 9 of 32
MMcCall402
in reply to: heidigoodrich
I edit the cui to make the open button set filedia=1 before it runs the open command. That way the open button always opens to a dialog window.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
Message 10 of 32
AllenJessup
If you ever do get caught with Filedia set to 0. You can open the file explorer box by entering a tilde (~) on the command line.
Allen Jessup
Engineering Specialist / CAD Manager
Message 11 of 32
Joe-Bouza
By getting under the hood and scraping your knuckles
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 12 of 32
austiego
This worked for me too!!! Thank you!
Message 13 of 32
rkmcswain
If Autodesk would have implemented my idea (posted almost 12 years ago), or something similar, we would not still be having these FILEDIA conversations today.
R.K. McSwain     | CADpanacea | on twitter
Message 14 of 32
nairb4606
research, trial, error, and time....
Message 15 of 32
yanlaikim
wow! thank you so much..FILEDIA solved my problem..thank you.
Message 16 of 32
0834002834
Gosh, thanx ...  this worked ... Awsome
Message 17 of 32
trobar.ce91
You just made my night. Thank you, thank you, thank you from the bottom of my heart. This forum is my "go to" for all questions!
Message 18 of 32
wayne
The scroll bars will not remain on the file that I am attempting to open.  they move to the bottom of the screen and the rt side.
Message 19 of 32
tcorey
in reply to: AllenJessup
That's a new one for me @AllenJessup!
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 20 of 32
AllenJessup
in reply to: tcorey
Comes from working with this software for way too many years!
Allen Jessup
Rail Community
