Member
0 Kudos
Post 1 of 7
Can't browse to open file
1807 Views, 6 Replies
07-12-2011 08:35 AM
When I open the software and try select "open", I have to type in the name of the drawing and path on the command line, it won't allow me to browse for the drawing or show recently used drawings.  I can work around this by typing in the path and name, but it is inconvenient.  Is there a setting that I need to change?
FILEDIA=1  I think (IIRC)?
Reid
Distinguished Mentor
24 Kudos
Post 2 of 7
Re: Can't browse to open file
07-12-2011 09:12 AM in reply to: CountyUser
Reid
Homebuilt box: I5-2500k, MSI P67A-GD65, 12gig DDR3 1600 ram, ASUS ENGTX460 Video card, WD Velociraptor WD4500HLHX HD, Win 7 64 pro.
Member
0 Kudos
Post 3 of 7
07-12-2011 09:17 AM in reply to: OMCUSNR
That worked!  Thank you!
New Member
0 Kudos
Post 4 of 7
02-02-2013 10:09 AM in reply to: CountyUser
My computer just started doig that.
Where do I type  "FILEDIA=1" ?
199 Kudos
Post 5 of 7
02-02-2013 11:35 AM in reply to: falcon125
Do you not have a command line? It may be you have turned it off but you should still be able to type commands. Press escape several times to cancel any active commands and then type FILEDIA and hit enter. Normally you would then see a prompt on the command line for inputting a value. If you can't see the command line just type the number one after hitting enter and you should then start getting the dialogues when opening files.
If you press Ctrl+9 it should restore your command line.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
194 Kudos
Post 6 of 7
02-02-2013 01:17 PM in reply to: Neilw
Since Autocad needs a path to open/save files, that means the command line is visible somewhere...
I concur with CTRL-9 or, even quicker, by pressing F2 to trigger the biggest text window.
New Member
0 Kudos
Post 7 of 7
02-04-2013 08:48 AM in reply to: CountyUser
Thanks. That worked.
