AutoCAD Civil 3D General Discussion
*Dave D
Message 21 of 25 (135 Views)
Re: Can't apply Service Pack 1
05-14-2004 11:08 AM in reply to: ddixon3
Hi Issac, 2 out of 3 ain't bad. I found 2 of the files that you asked me to look for. I did not find the MSP7 file in the .../local settings/temp/ folder. The files should be in the attached zip file. I tried the suggestions that Karen mentioned in her previous post. Still get the same "1624" error. Thanks, Dave Dixon "Isaac Rodriguez" wrote in message news:40a4ed2e_1@newsprd01... > Hi, > > Analyzing your log file, I've found that it is failing to apply the > transform to the Media table. This might be and indication of trying to > apply the wrong patch, but it also can be that your cached database is > corrupted. > > See if you still have in your machine the following file: > c:\Windows\Installer\22936.msi > > This is your cached database. You may have also the follwing file > C:\DOCUME~1\hdd\LOCALS~1\Temp\MSP7 > > This is the cached version of the patch you are trying to apply. > > Also, try to find this file, it is the transform that it is generated. > C:\WINDOWS\Installer\{5783F2D7-0200-0409-0000-0060B0CE6BBA}\Civil3D.mst > > See how many of those files you can find, zip them and post them here or > e-mail them to Karen. I will try to take a look at them and see what I can > find. > > Thanks, > > -- > > Isaac Rodriguez > SW Enginieer - Autodesk > ---------------------------------------- > There are 10 types of people. > Those who understand binary, > and those who don't. > > > "Dave D" wrote in message news:40a13891_3@newsprd01... > > > > "Karen Dowling, Autodesk ISD Test Development @autodesk.com>" > > wrote in message news:40a0e0d8$1_3@newsprd01... > > > Hi Dave, > > > We are still working on trying to figure out what the problem is. For > > what > > > it's worth, it appears to be an issue associated with your environment > as > > we > > > are not seeing other customers with the issue. > > > > > > ERROR_INSTALL_TRANSFORM_ FAILURE > > > 1624 Error applying transforms. Verify that the specified transform > > paths > > > are valid. > > > > > > I've checked at the Microsoft support site and this error is included on > > > their List of Error Codes for Windows Installer Process. > > > > > > -- > > > Karen Dowling > > > Autodesk ISD QA Analyst > > > > > > > > > > > > > > > > > > > > Karen, > > I've attached a verbose error log file of my failed install. This might > > help you pinpoint the problem. > > Dave > > > > > > > >
*Isaac Rodriguez
Message 22 of 25 (135 Views)
05-19-2004 10:40 AM in reply to: ddixon3
Looking at the files that you sent me was not of much help, other than it seems that the Media table is out of synch for some reason. I was reading previous postings and it seems that you originally installed from a network deployment. Have you tried to apply the patch to the network deployment and then reinstall from it? Thanks, -- Isaac Rodriguez SW Enginieer - Autodesk ---------------------------------------- There are 10 types of people. Those who understand binary, and those who don't. "Dave D" wrote in message news:40a50b8c_1@newsprd01... > Hi Issac, > > 2 out of 3 ain't bad. I found 2 of the files that you asked me to look for. > I did not find the MSP7 file in the .../local settings/temp/ folder. The > files should be in the attached zip file. > > I tried the suggestions that Karen mentioned in her previous post. Still > get the same "1624" error. > > Thanks, > Dave Dixon > > "Isaac Rodriguez" wrote in message > news:40a4ed2e_1@newsprd01... > > Hi, > > > > Analyzing your log file, I've found that it is failing to apply the > > transform to the Media table. This might be and indication of trying to > > apply the wrong patch, but it also can be that your cached database is > > corrupted. > > > > See if you still have in your machine the following file: > > c:\Windows\Installer\22936.msi > > > > This is your cached database. You may have also the follwing file > > C:\DOCUME~1\hdd\LOCALS~1\Temp\MSP7 > > > > This is the cached version of the patch you are trying to apply. > > > > Also, try to find this file, it is the transform that it is generated. > > C:\WINDOWS\Installer\{5783F2D7-0200-0409-0000-0060B0CE6BBA}\Civil3D.mst > > > > See how many of those files you can find, zip them and post them here or > > e-mail them to Karen. I will try to take a look at them and see what I can > > find. > > > > Thanks, > > > > -- > > > > Isaac Rodriguez > > SW Enginieer - Autodesk > > ---------------------------------------- > > There are 10 types of people. > > Those who understand binary, > > and those who don't. > > > > > > "Dave D" wrote in message > news:40a13891_3@newsprd01... > > > > > > "Karen Dowling, Autodesk ISD Test Development @autodesk.com>" > > > wrote in message news:40a0e0d8$1_3@newsprd01... > > > > Hi Dave, > > > > We are still working on trying to figure out what the problem is. For > > > what > > > > it's worth, it appears to be an issue associated with your environment > > as > > > we > > > > are not seeing other customers with the issue. > > > > > > > > ERROR_INSTALL_TRANSFORM_ FAILURE > > > > 1624 Error applying transforms. Verify that the specified transform > > > paths > > > > are valid. > > > > > > > > I've checked at the Microsoft support site and this error is included > on > > > > their List of Error Codes for Windows Installer Process. > > > > > > > > -- > > > > Karen Dowling > > > > Autodesk ISD QA Analyst > > > > > > > > > > > > > > > > > > > > > > > > > > > Karen, > > > I've attached a verbose error log file of my failed install. This might > > > help you pinpoint the problem. > > > Dave > > > > > > > > > > > > > > > >
*Dave D
Message 23 of 25 (135 Views)
05-19-2004 01:13 PM in reply to: ddixon3
Issac, I was in error in an earlier post when I mentioned that we have a network deployment. In fact, it is a client deployment. I do not know how to go about applying the service pack to the client deployment or if it's even possible. Dave "Isaac Rodriguez" wrote in message news:40ab9bf7$1_2@newsprd01... > Looking at the files that you sent me was not of much help, other than it > seems that the Media table is out of synch for some reason. > > I was reading previous postings and it seems that you originally installed > from a network deployment. Have you tried to apply the patch to the network > deployment and then reinstall from it? > > Thanks, > > -- > > Isaac Rodriguez > SW Enginieer - Autodesk > ---------------------------------------- > There are 10 types of people. > Those who understand binary, > and those who don't. > > > "Dave D" wrote in message news:40a50b8c_1@newsprd01... > > Hi Issac, > > > > 2 out of 3 ain't bad. I found 2 of the files that you asked me to look > for. > > I did not find the MSP7 file in the .../local settings/temp/ folder. The > > files should be in the attached zip file. > > > > I tried the suggestions that Karen mentioned in her previous post. Still > > get the same "1624" error. > > > > Thanks, > > Dave Dixon > > > > "Isaac Rodriguez" wrote in message > > news:40a4ed2e_1@newsprd01... > > > Hi, > > > > > > Analyzing your log file, I've found that it is failing to apply the > > > transform to the Media table. This might be and indication of trying to > > > apply the wrong patch, but it also can be that your cached database is > > > corrupted. > > > > > > See if you still have in your machine the following file: > > > c:\Windows\Installer\22936.msi > > > > > > This is your cached database. You may have also the follwing file > > > C:\DOCUME~1\hdd\LOCALS~1\Temp\MSP7 > > > > > > This is the cached version of the patch you are trying to apply. > > > > > > Also, try to find this file, it is the transform that it is generated. > > > C:\WINDOWS\Installer\{5783F2D7-0200-0409-0000-0060B0CE6BBA}\Civil3D.mst > > > > > > See how many of those files you can find, zip them and post them here or > > > e-mail them to Karen. I will try to take a look at them and see what I > can > > > find. > > > > > > Thanks, > > > > > > -- > > > > > > Isaac Rodriguez > > > SW Enginieer - Autodesk > > > ---------------------------------------- > > > There are 10 types of people. > > > Those who understand binary, > > > and those who don't. > > > > > > > > > "Dave D" wrote in message > > news:40a13891_3@newsprd01... > > > > > > > > "Karen Dowling, Autodesk ISD Test Development @autodesk.com>" > > > > wrote in message > news:40a0e0d8$1_3@newsprd01... > > > > > Hi Dave, > > > > > We are still working on trying to figure out what the problem is. > For > > > > what > > > > > it's worth, it appears to be an issue associated with your > environment > > > as > > > > we > > > > > are not seeing other customers with the issue. > > > > > > > > > > ERROR_INSTALL_TRANSFORM_ FAILURE > > > > > 1624 Error applying transforms. Verify that the specified > transform > > > > paths > > > > > are valid. > > > > > > > > > > I've checked at the Microsoft support site and this error is > included > > on > > > > > their List of Error Codes for Windows Installer Process. > > > > > > > > > > -- > > > > > Karen Dowling > > > > > Autodesk ISD QA Analyst > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Karen, > > > > I've attached a verbose error log file of my failed install. This > might > > > > help you pinpoint the problem. > > > > Dave > > > > > > > > > > > > > > > > > > > > > > > > > >
*Isaac Rodriguez
Message 24 of 25 (135 Views)
05-20-2004 06:44 AM in reply to: ddixon3
The Network Installer Wizard, which is the tool used to create the deployments, allows to apply a patch to an admin image (the image from where you installed). Then, you can run a re-install on your machine, and you will get the SP changes. You may want to talk to your network administrator about applying the patch to the deployment. Thanks, -- Isaac Rodriguez SW Enginieer - Autodesk ---------------------------------------- There are 10 types of people. Those who understand binary, and those who don't. "Dave D" wrote in message news:40abc043$1_3@newsprd01... > Issac, > I was in error in an earlier post when I mentioned that we have a network > deployment. In fact, it is a client deployment. I do not know how to go > about applying the service pack to the client deployment or if it's even > possible. > Dave > > "Isaac Rodriguez" wrote in message > news:40ab9bf7$1_2@newsprd01... > > Looking at the files that you sent me was not of much help, other than it > > seems that the Media table is out of synch for some reason. > > > > I was reading previous postings and it seems that you originally installed > > from a network deployment. Have you tried to apply the patch to the > network > > deployment and then reinstall from it? > > > > Thanks, > > > > -- > > > > Isaac Rodriguez > > SW Enginieer - Autodesk > > ---------------------------------------- > > There are 10 types of people. > > Those who understand binary, > > and those who don't. > > > > > > "Dave D" wrote in message > news:40a50b8c_1@newsprd01... > > > Hi Issac, > > > > > > 2 out of 3 ain't bad. I found 2 of the files that you asked me to look > > for. > > > I did not find the MSP7 file in the .../local settings/temp/ folder. > The > > > files should be in the attached zip file. > > > > > > I tried the suggestions that Karen mentioned in her previous post. > Still > > > get the same "1624" error. > > > > > > Thanks, > > > Dave Dixon > > > > > > "Isaac Rodriguez" wrote in message > > > news:40a4ed2e_1@newsprd01... > > > > Hi, > > > > > > > > Analyzing your log file, I've found that it is failing to apply the > > > > transform to the Media table. This might be and indication of trying > to > > > > apply the wrong patch, but it also can be that your cached database is > > > > corrupted. > > > > > > > > See if you still have in your machine the following file: > > > > c:\Windows\Installer\22936.msi > > > > > > > > This is your cached database. You may have also the follwing file > > > > C:\DOCUME~1\hdd\LOCALS~1\Temp\MSP7 > > > > > > > > This is the cached version of the patch you are trying to apply. > > > > > > > > Also, try to find this file, it is the transform that it is generated. > > > > > C:\WINDOWS\Installer\{5783F2D7-0200-0409-0000-0060B0CE6BBA}\Civil3D.mst > > > > > > > > See how many of those files you can find, zip them and post them here > or > > > > e-mail them to Karen. I will try to take a look at them and see what I > > can > > > > find. > > > > > > > > Thanks, > > > > > > > > -- > > > > > > > > Isaac Rodriguez > > > > SW Enginieer - Autodesk > > > > ---------------------------------------- > > > > There are 10 types of people. > > > > Those who understand binary, > > > > and those who don't. > > > > > > > > > > > > "Dave D" wrote in message > > > news:40a13891_3@newsprd01... > > > > > > > > > > "Karen Dowling, Autodesk ISD Test Development @autodesk.com>" > > > > > wrote in message > > news:40a0e0d8$1_3@newsprd01... > > > > > > Hi Dave, > > > > > > We are still working on trying to figure out what the problem is. > > For > > > > > what > > > > > > it's worth, it appears to be an issue associated with your > > environment > > > > as > > > > > we > > > > > > are not seeing other customers with the issue. > > > > > > > > > > > > ERROR_INSTALL_TRANSFORM_ FAILURE > > > > > > 1624 Error applying transforms. Verify that the specified > > transform > > > > > paths > > > > > > are valid. > > > > > > > > > > > > I've checked at the Microsoft support site and this error is > > included > > > on > > > > > > their List of Error Codes for Windows Installer Process. > > > > > > > > > > > > -- > > > > > > Karen Dowling > > > > > > Autodesk ISD QA Analyst > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Karen, > > > > > I've attached a verbose error log file of my failed install. This > > might > > > > > help you pinpoint the problem. > > > > > Dave > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
*Dave D
Message 25 of 25 (135 Views)
05-20-2004 11:31 AM in reply to: ddixon3
Ok. I will probably try this next week and I'll let you know how it goes. Thanks, Dave "Isaac Rodriguez" wrote in message news:40acb629$1_1@newsprd01... > The Network Installer Wizard, which is the tool used to create the > deployments, allows to apply a patch to an admin image (the image from where > you installed). Then, you can run a re-install on your machine, and you will > get the SP changes. > > You may want to talk to your network administrator about applying the patch > to the deployment. > > Thanks, > > -- > > Isaac Rodriguez > SW Enginieer - Autodesk > ---------------------------------------- > There are 10 types of people. > Those who understand binary, > and those who don't. > > > "Dave D" wrote in message > news:40abc043$1_3@newsprd01... > > Issac, > > I was in error in an earlier post when I mentioned that we have a network > > deployment. In fact, it is a client deployment. I do not know how to go > > about applying the service pack to the client deployment or if it's even > > possible. > > Dave > > > > "Isaac Rodriguez" wrote in message > > news:40ab9bf7$1_2@newsprd01... > > > Looking at the files that you sent me was not of much help, other than > it > > > seems that the Media table is out of synch for some reason. > > > > > > I was reading previous postings and it seems that you originally > installed > > > from a network deployment. Have you tried to apply the patch to the > > network > > > deployment and then reinstall from it? > > > > > > Thanks, > > > > > > -- > > > > > > Isaac Rodriguez > > > SW Enginieer - Autodesk > > > ---------------------------------------- > > > There are 10 types of people. > > > Those who understand binary, > > > and those who don't. > > > > > > > > > "Dave D" wrote in message > > news:40a50b8c_1@newsprd01... > > > > Hi Issac, > > > > > > > > 2 out of 3 ain't bad. I found 2 of the files that you asked me to > look > > > for. > > > > I did not find the MSP7 file in the .../local settings/temp/ folder. > > The > > > > files should be in the attached zip file. > > > > > > > > I tried the suggestions that Karen mentioned in her previous post. > > Still > > > > get the same "1624" error. > > > > > > > > Thanks, > > > > Dave Dixon > > > > > > > > "Isaac Rodriguez" wrote in message > > > > news:40a4ed2e_1@newsprd01... > > > > > Hi, > > > > > > > > > > Analyzing your log file, I've found that it is failing to apply the > > > > > transform to the Media table. This might be and indication of trying > > to > > > > > apply the wrong patch, but it also can be that your cached database > is > > > > > corrupted. > > > > > > > > > > See if you still have in your machine the following file: > > > > > c:\Windows\Installer\22936.msi > > > > > > > > > > This is your cached database. You may have also the follwing file > > > > > C:\DOCUME~1\hdd\LOCALS~1\Temp\MSP7 > > > > > > > > > > This is the cached version of the patch you are trying to apply. > > > > > > > > > > Also, try to find this file, it is the transform that it is > generated. > > > > > > > C:\WINDOWS\Installer\{5783F2D7-0200-0409-0000-0060B0CE6BBA}\Civil3D.mst > > > > > > > > > > See how many of those files you can find, zip them and post them > here > > or > > > > > e-mail them to Karen. I will try to take a look at them and see what > I > > > can > > > > > find. > > > > > > > > > > Thanks, > > > > > > > > > > -- > > > > > > > > > > Isaac Rodriguez > > > > > SW Enginieer - Autodesk > > > > > ---------------------------------------- > > > > > There are 10 types of people. > > > > > Those who understand binary, > > > > > and those who don't. > > > > > > > > > > > > > > > "Dave D" wrote in message > > > > news:40a13891_3@newsprd01... > > > > > > > > > > > > "Karen Dowling, Autodesk ISD Test Development @autodesk.com>" > > > > > > wrote in message > > > news:40a0e0d8$1_3@newsprd01... > > > > > > > Hi Dave, > > > > > > > We are still working on trying to figure out what the problem > is. > > > For > > > > > > what > > > > > > > it's worth, it appears to be an issue associated with your > > > environment > > > > > as > > > > > > we > > > > > > > are not seeing other customers with the issue. > > > > > > > > > > > > > > ERROR_INSTALL_TRANSFORM_ FAILURE > > > > > > > 1624 Error applying transforms. Verify that the specified > > > transform > > > > > > paths > > > > > > > are valid. > > > > > > > > > > > > > > I've checked at the Microsoft support site and this error is > > > included > > > > on > > > > > > > their List of Error Codes for Windows Installer Process. > > > > > > > > > > > > > > -- > > > > > > > Karen Dowling > > > > > > > Autodesk ISD QA Analyst > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Karen, > > > > > > I've attached a verbose error log file of my failed install. This > > > might > > > > > > help you pinpoint the problem. > > > > > > Dave > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
Announcements
Need installation help?
