Ok. I will probably try this next week and I'll let you know how it goes.
Dave
"Isaac Rodriguez" wrote in message
news:40acb629$1_1@newsprd01...
> The Network Installer Wizard, which is the tool used to create the
> deployments, allows to apply a patch to an admin image (the image from
where
> you installed). Then, you can run a re-install on your machine, and you
will
> get the SP changes.
> You may want to talk to your network administrator about applying the
patch
> to the deployment.
> Thanks,
> Isaac Rodriguez
> SW Enginieer - Autodesk
> There are 10 types of people.
> Those who understand binary,
> and those who don't.
> "Dave D" wrote in message
> news:40abc043$1_3@newsprd01...
> > Issac,
> > I was in error in an earlier post when I mentioned that we have a
network
> > deployment. In fact, it is a client deployment. I do not know how to
go
> > about applying the service pack to the client deployment or if it's even
> > possible.
> > Dave
> > news:40ab9bf7$1_2@newsprd01...
> > > Looking at the files that you sent me was not of much help, other than
> it
> > > seems that the Media table is out of synch for some reason.
> > > I was reading previous postings and it seems that you originally
> installed
> > > from a network deployment. Have you tried to apply the patch to the
> > network
> > > deployment and then reinstall from it?
> > > Thanks,
> > > Isaac Rodriguez
> > news:40a50b8c_1@newsprd01...
> > > > Hi Issac,
> > > > 2 out of 3 ain't bad. I found 2 of the files that you asked me to
> look
> > > for.
> > > > I did not find the MSP7 file in the .../local settings/temp/ folder.
> > The
> > > > files should be in the attached zip file.
> > > > I tried the suggestions that Karen mentioned in her previous post.
> > Still
> > > > get the same "1624" error.
> > > > Thanks,
> > > > Dave Dixon
> > > > news:40a4ed2e_1@newsprd01...
> > > > > Hi,
> > > > > Analyzing your log file, I've found that it is failing to apply
the
> > > > > transform to the Media table. This might be and indication of
trying
> > to
> > > > > apply the wrong patch, but it also can be that your cached
database
> is
> > > > > corrupted.
> > > > > See if you still have in your machine the following file:
> > > > > c:\Windows\Installer\22936.msi
> > > > > This is your cached database. You may have also the follwing file
> > > > > C:\DOCUME~1\hdd\LOCALS~1\Temp\MSP7
> > > > > This is the cached version of the patch you are trying to apply.
> > > > > Also, try to find this file, it is the transform that it is
> generated.
> > C:\WINDOWS\Installer\{5783F2D7-0200-0409-0000-0060B0CE6BBA}\Civil3D.mst
> > > > > See how many of those files you can find, zip them and post them
> here
> > or
> > > > > e-mail them to Karen. I will try to take a look at them and see
what
> I
> > > can
> > > > > find.
> > > > > Thanks,
> > > > > Isaac Rodriguez
> > > > news:40a13891_3@newsprd01...
> > > > > > "Karen Dowling, Autodesk ISD Test Development @autodesk.com>"
> > > > > > wrote in message
> > > news:40a0e0d8$1_3@newsprd01...
> > > > > > > Hi Dave,
> > > > > > > We are still working on trying to figure out what the problem
> is.
> > > For
> > > > > > what
> > > > > > > it's worth, it appears to be an issue associated with your
> > > environment
> > > > > as
> > > > > > we
> > > > > > > are not seeing other customers with the issue.
> > > > > > > ERROR_INSTALL_TRANSFORM_ FAILURE
> > > > > > > 1624 Error applying transforms. Verify that the specified
> > > transform
> > > > > > paths
> > > > > > > are valid.
> > > > > > > I've checked at the Microsoft support site and this error is
> > > included
> > > > on
> > > > > > > their List of Error Codes for Windows Installer Process.
> > > > > > > Karen Dowling
> > > > > > > Autodesk ISD QA Analyst
> > > > > > Karen,
> > > > > > I've attached a verbose error log file of my failed install.
This
> > > might
> > > > > > help you pinpoint the problem.
> > > > > > Dave
