Typically, this is caused by a resizing of the data entry fields. If you can
go to the edge and hover there, your cursor should change - once it does,
click and drag to make the field wider and you should then be able to enter
data into the field.
Jason Hickey
Autodesk, Inc.
http://beingcivil.typepad.com
"lwkelly" wrote in message news:6239080@discussion.autodesk.com...
I was following Civil 3D 2008 Education Curriculum Module 04-Survey on how
to import field books, create points and figures, insert them into the
drawing, and then (per page 04-35), remove the network from the drawing.
Now I have a serious problem, and cannot add any new Networks. The "Name"
and "Description" appears, but there is no place for a cursor entry.
Do I have to re-install the program???
