I will be using the stripping pavement subassembly. I would like to strip 1.0' but in a Deeper fill I only need to strip 5' below finish grade. Is it possible to limit stripping. I can't find a way
please see attached
thanks
I'm not sure if you figured this out yet, but I'm pretty sure you could create a featureline from your corridor that you can target on your stripping SA. I'm not sure if you can do this based on just a depth from your origin though.
