Civil 3D Forum
Can Stripping be Limited
1 REPLY 1
vcoleman
416 Views, 1 Reply
I will be using the stripping pavement subassembly.  I would like to strip 1.0' but in a Deeper fill I only need to strip 5' below finish grade.  Is it possible to limit stripping.  I can't find a way
please see attached
thanks
1 REPLY 1
LeafRiders
in reply to: vcoleman
I'm not sure if you figured this out yet, but I'm pretty sure you could create a featureline from your corridor that you can target on your stripping SA. I'm not sure if you can do this based on just a depth from your origin though.
Rail Community
