0 Kudos
Post 11 of 14
Re: Can not purge blocks
11-14-2012 12:01 PM in reply to: jrauch
We recieved some files from an architect and they contained a bunch of stuff that has been since embeded into our base files.  It's making our drawings incredibly slow and frustrating the entire team.  We are way too far along to try and re-build new line work.  Copying our likework out and wblocking have all resulted in these entities being carried through.
Ryan
Civil 3D 2013
919 Kudos
Post 12 of 14
11-14-2012 12:09 PM in reply to: RyanElam
And here's another, safer, variation that will only remove the blocks created by Group:
(vlax-for blk (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
  (if (wcmatch (vla-get-name blk) "`*A*")
    (vla-delete blk)
 Or another that does the Group blocks and Anonymous blocks:
  (if (wcmatch (vla-get-name blk) "`*A*,`*U*")
    (vla-delete blk)
267 Kudos
Post 13 of 14
11-14-2012 12:14 PM in reply to: Jeff_M
Here's one that explodes anonymous blocks, something that was driving me nutty:
(defun c:test (/ ss old-echo item ss1 item1)
  (setq old-echo (getvar "CMDECHO"))
  (setvar "CMDECHO" 0)
  (if (setq ss (ssget '((2 . "`*U*"))))
    (foreach item (mapcar 'cadr (ssnamex ss))
      (command "Explode" item)
      (while
	(setq ss1 (ssget "_P" '((2 . "`*U*"))))
	 (foreach item1	(mapcar 'cadr (ssnamex ss1))
	   (command "Explode" item1)
  (setq ss nil)
  (setq ss1 nil)
  (setvar "CMDECHO" old-echo)
  (princ)
 Don't know if that is related or not.
Credit where credit is due! Give kudos or accept as solution whenever you can.
0 Kudos
Post 14 of 14
11-14-2012 04:03 PM in reply to: troma
I ended up exporting the linework base file I had to a DXF file and then brought it back in.  This allowed me to then purge all of the blocks I was unable to see or purge before.  I'm not sure if that's the best way to do it, but nothing else was working.  Luckily I didn't have to do something like that to a file that had any built in intelligence, it was just lines.  Thanks for everyone's help.
Ryan
Civil 3D 2013
