Hello to everybody!
A drawing with hundreds of layers should be simplified for our customer by decreasing the numbers of and renaming the layers (there is yet no target file existing). In order to solve this, I generated group filters and assigned every single layer to them (all printing properties are assigned to objects). The layer groups show the desired layer structure after the transformation (still a three-digit number).
Unfortunately, the LAYTRANS dialog doesn't let me choose layers by group filters or remarks. It seems as all the work was for the birds.
Is there any way to translate my layers using filters or remarks?
Thanks a lot for your help!
Best regards, Tina
I use AutoCAD Civil 3D 2010.
welcome @forums.autodesk.com !
Correct, you can use wildchars to filter layers together, if you use layernames that don't allow using wildchars for filtering you can't to that (efficient) with _LAYTRANS.
Starting with AutoCAD 2014 you have the option to merge layers using the layermanager ==> select the layers in your like your layerfilter ==> "Merge selected layer(s) to...".
So if you have access to 2014 that might be the first option without development.
But that is a function new for 2014, not availsable for 2010.
And important: I guess that might be problematic to Civil3D objects, if you have defined styles using layers other than "0" you might corrupt your styles and so your objects using such a merge.
Is decreasing the number of pages of a book the way to simplify it? My personal opinion to many layers (and well formed layernames) is (in most cases) "well structured", decreasing the layers is making a drawing less structured, not more simply.
Sorry to say, but that is how I never want to get data. You can't control the properties like color, lineweight, linetype, ... now in an easy way. Did you built that just for this one case or do you have apps that are working that way?
If nothing works I guess you need to write your own tool doing that (or let it write).
Good luck, - alfred -
Hi Alfred,
your reply gave me a big smile - even when I'm none the wiser.
While working on this job, I doubt its sense. But we meet the customer's needs. And they want a secretary who may hit the AutoCAD-button to produce a drawing showing i.e. buildings, trees and roads. For buildings only we use about 50 layers - reasonable well structured and individually editable in appearance. Too much for the costumer's secretary!
I could not even convince them to use layerstates, they want an extreme "down-layering".
In any case, I'll need and keep the current structure. This is why LAYTRANS seems to be the right way to do this job (since I have no experiences in programming LISP) and afterwards keep the mappings at a safe place 😉
Take care,
Tina
If anyone uses non-trained employees to do something then this "anyone" has to solve the problem either with training the employee or with money spent in writing tools doing that job.
AutoCAD has the aibility to write some tools to create automatism that is not available OOTB, take the chance either to learn it or let someone write the tool. Some hours development makes it then easier/more efficient in the future.
BTW: have you played with the LAYTRANS ==> "save mapping" option? Does that help or are the drawings always structured differently (in that case also a tool might not help).
- alfred -
