I am trying to find a way to insert pipe elements (pressure piping) to record survey nodes. I have survey shots at each joint and thought it should be relatively easy to generate plan/profile for each run of the system. It seems that I have to edit each length to place it at the correct elevation. Any suggestions will be greatly appreciated.
