Distinguished Contributor
rhdins
Message 1 of 7 (333 Views)
Can I Edit Pipe Elevations In a Table?
333 Views, 6 Replies
09-11-2013 06:39 PM
I have a pipe network, and I would like to edit the elevations of multiple pipes, similar to how I would edit the elevations of a feature line or an alignment, in a table.  I can't figure out how to edit these besides just selecting pipe properties on each individual pipe.
Any help would be much appreciated.
Jeff_M
Message 2 of 7 (325 Views)
Re: Can I Edit Pipe Elevations In a Table?
09-11-2013 08:36 PM in reply to: rhdins
Yes. Edit the network. On the network layout tools bar select the icon second from the right to open the vistas. There will be 2 tabs, one for pipes the other for structures.
rhdins
Message 3 of 7 (297 Views)
09-12-2013 12:07 PM in reply to: Jeff_M
:smileysurprised:
Active Member
tadas.jan
Message 4 of 7 (244 Views)
10-20-2013 11:34 PM in reply to: rhdins
in table you have change each pipe elevation manually. Is there any way to change entire network elevevation, for exmaple -0,2 for all. This would be useful in case of topology mistake, when it is needed to correct them by relative elevation -0,2. Change surface elevation is easy option, but how on pipe network?
Joe-Bouza
Message 5 of 7 (220 Views)
10-21-2013 07:20 PM in reply to: tadas.jan
select all the pipes in the network and envoke the move command: at the command line enter 0,0,0 for the base point and 0,0,-.2 for the destination.
all your inverts will go down -.2
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Active Member
tadas.jan
Message 6 of 7 (206 Views)
10-23-2013 03:55 AM in reply to: Joe-Bouza
Thanks, works..
Joe-Bouza
Message 7 of 7 (196 Views)
10-23-2013 04:46 AM in reply to: tadas.jan
I'd like to give credit to Matt Anderson for that one.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
