Civil 3D Forum
Can I Edit Pipe Elevations In a Table?
6 REPLIES 6
rhdins
1880 Views, 6 Replies
I have a pipe network, and I would like to edit the elevations of multiple pipes, similar to how I would edit the elevations of a feature line or an alignment, in a table.  I can't figure out how to edit these besides just selecting pipe properties on each individual pipe.
Any help would be much appreciated.
6 REPLIES 6
Jeff_M
in reply to: rhdins
Yes. Edit the network. On the network layout tools bar select the icon second from the right to open the vistas. There will be 2 tabs, one for pipes the other for structures.
rhdins
in reply to: Jeff_M
tadas.jan
in reply to: rhdins
in table you have change each pipe elevation manually. Is there any way to change entire network elevevation, for exmaple -0,2 for all. This would be useful in case of topology mistake, when it is needed to correct them by relative elevation -0,2. Change surface elevation is easy option, but how on pipe network?
Joe-Bouza
in reply to: tadas.jan
select all the pipes in the network and envoke the move command: at the command line enter 0,0,0 for the base point and 0,0,-.2 for the destination.
all your inverts will go down -.2
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
tadas.jan
in reply to: Joe-Bouza
Thanks, works..
Joe-Bouza
I'd like to give credit to Matt Anderson for that one.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Rail Community
