I have a pipe network, and I would like to edit the elevations of multiple pipes, similar to how I would edit the elevations of a feature line or an alignment, in a table. I can't figure out how to edit these besides just selecting pipe properties on each individual pipe.
Any help would be much appreciated.
Solved by Joe-Bouza. Go to Solution.
Solved by Jeff_M. Go to Solution.
in table you have change each pipe elevation manually. Is there any way to change entire network elevevation, for exmaple -0,2 for all. This would be useful in case of topology mistake, when it is needed to correct them by relative elevation -0,2. Change surface elevation is easy option, but how on pipe network?
