Civil 3D Forum
Can I batch convert DWG files to DXF files?
5 REPLIES 5
BrianBenton
5276 Views, 5 Replies
We have to submit a set of 18 drawings to a local municipality.  They want the CAD files (in this case Civil3D 2011) in .DXF format.  Is there an easy way to convert them all at once or do I have to SAVEAS each file one at a time?
Thanks.
Brian C. Benton
bbenton@cad-a-blog.com
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
5 REPLIES 5
troma
in reply to: BrianBenton
Could be done with a script running the DXFOUT command.
Mark Green
Working on Civil 3D in Canada
rkmcswain
I guess you have already looked at DWG Trueview...which does not include the explode/strip AEC content option...
I will be watching for an answer here too....
R.K. McSwain     | CADpanacea | on twitter
BrianBenton
in reply to: troma
Script file is a good idea.  But how do I get it to open the proper files on it's own?
Brian C. Benton
troma
Have you run scrips before?  I haven't done much, not anything really.  I just tested some out to see how it would work. You can download Script Pro for free from AutoDesk.  You create a list of drawings and give it a script, and then let it run.
Mark Green
BrianBenton
in reply to: troma
I haven't run a script file in a while.  I forgot about scriptpro.  Thanks for the tip.  This will probably do it.
Brian C. Benton
Rail Community
