Civil 3D Forum
can i add a surface to a section view after the sample lines are run?
3 REPLIES 3
MKH-VB
3043 Views, 3 Replies
I have created a surface, applied sample lines to that existing surface, and created section views for it.  I have since added a surface representing a proposed surface. Is there anyway to update my sections using the existing and proposed without re-doing my sample lines? Not a big deal to redo them with both surfces, but was just thinking maybe I could. Thanks for any help.
MKH
mkh
3 REPLIES 3
Jeff_M
in reply to: MKH-VB
Yes, go to the Sample Line Group Properties, Sections tab, select the "Sample more sources ..." button.
Jeff_M, also a frequent Swamper
MKH-VB
in reply to: Jeff_M
thanks very much. That's what I was looking for.
mkh
neilyj666
in reply to: MKH-VB
It also appears on the contextual ribbon when you select a section
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
