I may be looking into the wrong thing here.
What I want to do is create a block/attribute/callout..... referencing the sheetset.
I want to be able to have ie - See Sheet 3 (listed on sheet 2) and if sheet 3 is changed to 4 have this update. The layouts may or may not be in the same drawing.
How can I set up the sheetnumber or layout so you can select it from the sheetset?
With everything else you can do with the sheetset, I figure this can be done, but I am just looking in the wrong spot for the info.
(C3d 2011)
Solved by Joe-Bouza. Go to Solution.
This is exactley what SSM does for you. there are a few ways of doing this; if you are refering to a detail, section or some other "view with in the SS you would do this via saved views, view lable and callout blocks. I cnat find my white papers, they are out there. Brian Hailey postesd them heer a few weeks back give that a search
Joe Bouza
