Call me lazy but is there somewhere we can purchase a AWWA pressure pipe catalog parts list? The company i work for doesn't have the time or resources to build our own parts. It's great that 2014 comes preloaded with ductal iron pipes and fittings but here in Florida DIP is only used when we cross a road or have separation issues.
Hello Lazy,
You said to call you that...
But, seriously, Joe, if you post in the Autodesk classifieds discussion group, here: http://forums.autodesk.com/t5/Classifieds/bd-p/119, you might find someone with experience who can build them for you.
Best regards,
Tim
Tim,
Thanks for the idea. I will post something today.
Best Regards,
Lazy 🙂
I don't quite understand. It will cost more for a parts list than just making your own. It doesn't take more than a couple hours.
Anyway, last time I had to do this was using 2011. I just made blocks for a profile and plan views of valves and tees and set up a new structure for each of those. I didn't have pressure network (I was using 2011) so I just used DIP from the storm sewers.
For hydrants I just used a projected block.
Why can't you use the ductile iron fittings for the drawings? Also, what kind of fittings are you using?
We did the same using pipe networks. However the features in the pressure pipe are a huge benifit when doing a OPC. If you look into what it takes to make your own gate valves, fire hydrants, bactieral sample points, tee's, reducers, (the list is quite large) it takes a lot of understanding building parts in 3d. We simply don't have the resources nor do I have the time to do it myself (or i would). I have been working 60hr weeks since 2011 and like i said... i just don't have the time to create them.
DIP in Florida is typically only used in certain counties, and or if you break a required vertical/horizontal sepertation. We use HDPE and Steel for casing pipes when in a directional bore situation and when we are crossing under pavement we use a thicker class of PVC (DR-14)
So just using DIP will not do. I shouldn't have to trick the styles or Civil3d for that matter, by using DIP and calling it something else. Does me know good when I want to run a OPC report.
Why shouldn't you have to trick the styles? Civil 3D is a tool, not a solution, you have to use it how you can to accomplish what you need.
Why not simply count the valves, hydrants, bends, tees, etc. and create your own OPC report? That's what I've always done. You can have an intern do the quantity take-offs. You still have to get unit prices for your report, so what is the advantage of Civil 3D other than the take-offs?
How did you prepare other water distribution plans? You can always revert to an older method.
As far as creating your own custom pieces from blocks, as I was saying. You really don't need to make that many. One for tees, valves, hydrants, reducers, and vertical bends (3 maximum, 45, 22.5, 11.25). You can scale the blocks for different size pipe. I just draw in meter vaults, pump stations, and other infrequent installations as necessary.
Also, I am familiar with C-900 pipe. We use it here in Ohio, although it depends on municipality. I'm just giving you tips based on what I've done in the past. Remember, you don't need a sledghammer to kill a fly.
We have interns do take-off's but the fact is we still have human error there. If a designer has Civil generate the OPC your taking most of the error out of it. It's doubtful that we would ever put unit pricing into Civil, however, the quantities it generates is extremely valuable. Especially when doing sidewalks, curb, sub-grade, limerock, and pavement.
The older method was using pipe networks to create water/force/irrigation etc. Those were using blocks but doesn't work as well as the pressure pipe feature. You can't just take blocks to create pressure parts either. They have to be 3D solids to start will. Furthermore we have some municipalities that require that you show fittings in profile view. Pipe networks is not the answer for this. Autodesk got it right with the pressure pipe though. It will allow you to move and add parts in profile view and will translate to plan view. Thus ensuring that your fittings/appurtenances are in the correct location.
I think creating pipe parts isn't going to be all that diffcult or time consuming but appurtenances, and adding reducers to the catalog isn't easy. All the research I've done basically tells you to run unless you really know what your doing in the content catalog editor.
Again, Autodesk did a great thing here adding the pressure network feature! I just hope there is something out there that allows me to add more parts without having to do them myself. We use a lot of 4" gate valves on our reuse/irrigation systems and the smallest valve Autodesk added is a 6". Wish they would have just offered a add-on or something to complete the package.
Build your own? "I ain't got no time fo dat" LOLZ
I'll take a lirbary if you can post one.
We will buy one if anything is out there but I can't find anything!
I think we would all buy one if it were availiable.
I found this in my search for the same thing yesterday. However, I have not contacted them to inquire about pricing.
I found one that has all the parts that I need. You should look into it.
Did anyone ever come up with a comprehensive parts list for sharing? I need reducers, hydrants, sleeves, butterfly valves, caps, plugs, live tap valves, all of it. I work for a water utility that owns 800 miles of pipe that is being systematically replaced. We run into all kinds of situations and need every part there is to accomodate the infrastructure upgrade while maintaining service.
I tried to add a hydrant. The solid model looks like a hydrant, and I have the CL defined and a connection point. Unfortunately my PC will not run Autodesk.Aec.Content.CatalogEditor.exe (see post in the Installation forum where I describe my issue), so I cannot add the part to the catalog.
I cannot use pressure pipes to completely model the system. Does anyone still use regular old pipe networks to model water? I'm mostly interested in plan production and quantities.
PS the links to the catalogs toward the end of this post return 404 errors. Like C3D does when I tried to add a hydrant!
Oh, Civil 3D 2015 here.
Mark Green
Working on Civil 3D in Canada
