Civil 3D Forum
Call for Cul-de-sac Examples
25 REPLIES 25
Message 1 of 26
1000 Views, 25 Replies
In Civil 3D, we would like to expand our solution base for Cul-De-Sac
creation, as well as improve useability. We hope to get are some particular
common (and not-so-common) configurations for Cul-de-sacs, in regards to the
horizontal alignment, offsets and, additionally, 3D design details to help
automate the process.
Preferred examples would be contained in DWF or DWG files. Also, any
available agency standards and examples would be useful as well. We seek
this input to continue improving Autodesk Civil 3D.
If you can help, please respond/send examples directly to me at the
following email address:
mike.rogerson - Add "autodesk.com" at the end of that. If you reply
directly to me from this post, make sure to remove the SPAM protection from
my reply address.
Thanks for any help!
Mike
Autodesk, Inc.
Michael C. Rogerson, PE
Product Designer - Program Manager
ISD Civil Engineering Software Development
25 REPLIES 25
Message 2 of 26
Mike,
Below is a link to the Riverside County web site that contains Standard geometric drawings.
http://www.tlma.co.riverside.ca.us/trans/ord461index.html
Riverside County Trans. Standard Drawings online
I can give you vertical info if you want.
Gene Redmon
Message 3 of 26
Hi Gene,
How are you? Thanks for the link - I do have some questions about the
vertical design. In both cases on their guide, the CL ends abruptly at the
center of the cul-de-sac. Now I'm assuming that for the vertical design, a
profile of the curb around the loop is provided? If so, is it plotted in
relation to the CL?
The other thought - does the CL sometimes get extended past the endpoint
that is shown, and that is how the curb elevations are shown in relation to
the CL?
Or... Is some other method used? Feel free to reply directly to me, or to
group, perhaps this will spur some more discussion.
Mike
"gredmon" wrote in message
news:f19b375.0@WebX.maYIadrTaRb...
Mike,
geometric drawings.
Gene Redmon
Message 4 of 26
In our plans, cul-de-sac grading is typically down by showing spot shots. We
profile based on center line, stopping at the curb return. Grading is done
by hand (sloped 3Dpolys), and shown by points. The station-offset paradigm
doesn't work well in cul-de-sacs, so it's not used.
James Wedding, P.E.
IT Manager
Jones & Boyd, Inc.
Dallas, TX
XP/1 on P4-1.6/512
LDT2004+C3D
Message 5 of 26
Ditto here. We do a lot of residential cul-de-sacs that are warped in every
possible way. They are all done by hand and shown with spot shots because
the high or low points could be anywhere on the curves.
John Mayo
"James Wedding" wrote in message
news:1C54AB7460E4252BD832A92B17E17B9B@in.WebX.maYIadrTaRb...
We
> James Wedding, P.E.
> IT Manager
> Jones & Boyd, Inc.
> Dallas, TX
> XP/1 on P4-1.6/512
> LDT2004+C3D
Message 6 of 26
Good stuff.
It seems there are so many ways to approach the grading of a cul-de-sac.
I've seen situations where the CL actually wraps around the end loop, so
elevations and offsets can be forced from the CL profile but as you probably
have experienced, there is always some sort of "manual" grade determination
in areas.
In the situation of the CL ending at the center, it seems that it may be
much more free-form, as you mention, John "warped in every possible way". I
assume you've typically worked radially from the CL end - grading out to the
curb limits with some min/max grade criteria to determine your points?
Have you ever created an alignment./profile around the curb and set points
that way?
thanks!
Mike
"John Mayo" wrote in message
news:D2279403149408B579D9FD4693FEB676@in.WebX.maYIadrTaRb...
every
> John Mayo
shots.
> We
done
paradigm
> > James Wedding, P.E.
> > IT Manager
> > Jones & Boyd, Inc.
> > Dallas, TX
> > XP/1 on P4-1.6/512
> > LDT2004+C3D
Message 7 of 26
I wish our regulators would allow spot elevations for flowline design. We
have to show gutter flowline profiles with their own stationing to show true
gutter slopes every where.
It would be nice if in Civil 3D they could finally figure out how to show
FGCL and two transition profiles (gutter flowline) with the transitions'
actual lengths and longitudinal slopes in the same Profile View. For
example, the Profile View would have to be as long as the longest
transition profile.
Fred
Message 8 of 26
Fred, do you have any drawing (plan/profile) examples you could send me?
Do you mean drawing the transition lines at the true length, or annotating
them?
Mike
"> It would be nice if in Civil 3D they could finally figure out how to show
> transition profile."
"Fred Ernst" wrote in message
news:B5B299BB5C86F97AC31F37D81FB88436@in.WebX.maYIadrTaRb...
true
> transition profile.
> Fred
Message 9 of 26
On each plan and profile sheet we have to show three profiles: FGCL, left
gutter flowline and right gutter flowline. Each has their own stationing
because the flowlines are longer and\or shorter than FGCL due to curves and
transitions.
It would be huge if you could get the three into one Profile View. With the
Profile Data Band sets in Civil 3D you could have a data band for each
profile. Each of the three profiles need to be fully annotated (i.e, grades,
vertical curves, PVI's, etc.)
The regulators want to make sure the gutter flowlines are working for
drainage puposes. They want to make sure they're not getting too flat around
curves and through transitions.
This would be just huge.
Fred
Message 10 of 26
Fred - Sheesh, you guys want everything. 🙂 Kidding.
Actually, we've had that on our radar for some time. Maybe I need a kick in
the head or something, but there were some details about the stationing from
offset to offset to CL that I'm a little fuzzy on. I'm sending you a direct
email to get some more details.
Thanks!
Mike
news:B0AC9A9C16B5F6948F3EE600456C0FE3@in.WebX.maYIadrTaRb...
and
> transitions.
the
grades,
around
> Fred
Message 11 of 26
Hi Mike:
The grid would be based on CL. At each interval we would label all three
alignment's stationing relative to CL. If the left flowline is longest we
would have something like:
Example: at CL Sta. 12+00, we would have 12+00CL, 13+23 LT, 11+15 RT.
The transition vertical elements; tangents, PVI's and VC, info in the
Profile would be smart to allow labeling of true grades and stations based
on each alignment's true length.
Our roads are designed using the template tools, but we have no way of
outputting the true grades of the transitions. Along these lines it would
also be helpful if there were design tools to see the transition true slopes
during the design process. We also need to see the road cross slope
relationship to make sure we're maintaining our 2%-4% road crown cross slope
criterion when the offset is constrained laterally, as in gutter design.
Fred
"Michael Rogerson" wrote in message
news:A8D7F0AEA04C65A842E40BD8DC465611@in.WebX.maYIadrTaRb...
in
from
direct
> Thanks!
> Mike
left
> and
> > transitions.
> the
> grades,
> around
> > Fred
Message 12 of 26
Fred,
Thanks, you've answered it. The labeiling of the true grades and stations
(not the transposed grades) is the critical point, as I though - just wanted
to make sure. As you may know, we have the "Superimpose" profile feature in
LDD, but labeling is only with respect to the CL for which the profile
belongs to. I can relate how tough it must be to label all of the info from
the transposed profile grade lines. Stay tuned.
Mike
news:581776AFCE3C85B7E7D15ED05444D834@in.WebX.maYIadrTaRb...
> Hi Mike:
slopes
slope
> Fred
message
kick
> in
> from
> direct
> > Thanks!
> > Mike
> left
stationing
curves
> > and
> > > transitions.
With
> > the
> > grades,
> > around
> > > Fred
Message 13 of 26
Michael,
No we have not had the need to do that. We usually have a CL profile and
work off of that forcing 3dpolys to get desired cross slopes or gutter flow.
None of the local agencies around here require us to show profiles around
the curbline and 3dpolys work great to achieve what we want. After we get
the 3dpolys we just label the critical elevations.
John
news:C2BEAB95B16B73DFF4162AE9753EFFD5@in.WebX.maYIadrTaRb...
> Good stuff.
probably
determination
> in areas.
I
the
> that way?
> thanks!
> Mike
> every
because
> > John Mayo
> shots.
> > We
> done
> paradigm
> > > James Wedding, P.E.
> > > IT Manager
> > > Jones & Boyd, Inc.
> > > Dallas, TX
> > > XP/1 on P4-1.6/512
> > > LDT2004+C3D
Message 14 of 26
Mike,
Yes I do know about the feature and it helps for attaching Profiles to
Transitions.
Yes, it's a tremendous amount of work to transpose all that information.
I'll be on standby.
Fred
news:18C8FDA161100B1BBB6C28BB8625FED0@in.WebX.maYIadrTaRb...
> Fred,
wanted
in
from
> Mike
> > Hi Mike:
we
based
would
> slopes
> slope
> > Fred
> message
> kick
> > in
stationing
> > from
> > direct
> > > Thanks!
> > > Mike
> > left
> stationing
> curves
> > > and
> > > > transitions.
> With
> > > the
each
> > > grades,
for
flat
> > > around
> > > > Fred
Message 15 of 26
This is a great topic coming from Autodesk. I have seen the routines in
the programs for years but didn't find any usefulness in then with our
designs. Hopefully I can use them in the future.
I have designed Cul-de-sacs using centerline stationing up to the curb
returns at the start of the cul-de-sac then use LT/RT curb stationing to
to a point equal distant from each curb return. I then make my
alignment for the cul-de-sac run through the end of the cul-de-sac to
the length equal to the ending station of the curb stationing. that
reserves the distance in the profile. I create my profile and then trim
my existing ground at the curb return then use a quickview of the curb
returns to insert the natural ground of the LT and RT curb.
for the profile we will usually fake in a vertical curve in at the end
with the center of the VC at the end of the alignment then trim it out
from beyond the end of the alignment. If I end up with split curbs then
I just need to make sure the grade into the end of the alignment is the
negative of the grade of the other curb at the end of the alignment.
We have a document that explains our design for Autocad that I could send.
David Urban, P.E.
Huffcut & Associates
Austin, Texas
> my reply address.
> Mike
> Autodesk, Inc.
Message 16 of 26
Thanks David, I got the example - I defintely will have some questions as I
walk throught he procedure, not an easy one - this will also be a great test
to see of the profile features are up to the task.
regards,
Mike
"David Urban, P.E." wrote in message
news:D7B76CB3EF7C177E9F7CC9FBFD7FB82E@in.WebX.maYIadrTaRb...
> David Urban, P.E.
> Austin, Texas
particular
the
help
seek
from
> > my reply address.
> > Mike
> > Autodesk, Inc.
Message 17 of 26
Mike,
Our situation is similar to Fred's further down in this thread. We are required to show all 3 profiles. Left curb, CL and Right curb. They all must be fully annotated with actual lengths shown where curbs are not parallel with CL.
Our CL profile actually always continues to the top of curb in the middle of the the large radius (back of cul-de-sac) where all the profiles end at an identical point.
This method provides us the opportunity to control all the warping in the cul-de-sac with individual profiles and provide curb staking onsite.
Hope this helps.
Gene
Message 18 of 26
Howdy Gene,
Thanks, understand - a common need seems to be the
ability to first plot, then annotate parallel and non-parallel offsets on the CL
profile (or onto any profile for that matter).
The annotation of the non-parallel entities as
superimposed on the CL profile needs a few things:
1) Label true grades along the offset (not the
grades as the appear in the CL profile)
2) The abiliy to label stations along the
offset (not the CL stations) on the CL profile.  These stations distances
would be non-linear in the case where an offset was non-parallel, curved or
bent.
From you comments, I'm assuming that for design
development, you would likely work with profiles for the offsets as well as the
centerline.  But, for review and construction drawings, these would often
all be represented on the CL profile?
let me know if I'm not clear here, or
off-base.  Thanks.
Mike
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Mike,
CL.
identical point.
Hope this helps.
Gene
Message 19 of 26
I know this is no easy task, but its what we have to do.
As far as the 3 lines of the profile. You mention design development and construction drawings. Right now there is no difference. We use a custom app built on LDT to design all 3 lines of the profile simultaniously (each line gets its own horiz. alignment) then produce a single profile that shows all 3 lines separated vertically by a 100 grid. This profile gets externally referenced into our construction drawings for plots that are used for plan check and construction staking.
If I understand what your suggesting is that 3 different profiles could be used to develop the design and then brought together as a representation on a single (CL) profile for construction drawings should work. In theory...
Let me know if I miss understood.
Gene
Message 20 of 26
Hi Michael:
We actually need the ability to design the
transitions (gutter flowline usually) as "independent" alignments and profiles,
but they need to have an intelligent cross slope relationship with CL. We need a
flag or a display where we can see the cross slope left and right of crown
at each CL station.
Now, people are designing all three profiles, and
"hand checking" the crown cross slopes, which is very tedious and eats profit
margins.
Fred
Howdy Gene,
the ability to first plot, then annotate parallel and non-parallel offsets on
the CL profile (or onto any profile for that matter).
bent.
the centerline.  But, for review and construction drawings, these would
often all be represented on the CL profile?
off-base.  Thanks.
Mike
Mike,
with CL.
an identical point.
Hope this helps.
Gene
Rail Community
