AutoCAD Civil 3D General Discussion
Distinguished Contributor
mnorton
Message 1 of 13 (1,269 Views)
Calculating VC for Lowboy clearance
1269 Views, 12 Replies
10-15-2012 07:50 AM
I'm in search of a method/software to design a low vehicle clearance vertical curve.  The access road to my site crosses a levee and I need to bring in equipment on a 40' lowboy trailer with 8" clearance.  I've searched AASHTO, AREMA, ITE, DOTs, and various manufacturers to no avail.
Norton
Mike Norton - The Civil Guy
www.thecivilguy.com
Civil 3D 2014 (64)
Windows 7 Pro (64) SP1, 16 GB
AMD Radeon HD 6900
Valued Contributor
witzel
Message 2 of 13 (1,247 Views)
Re: Calculating VC for Lowboy clearance
10-15-2012 09:42 AM in reply to: mnorton
Mike,
Let me know if you find anything.
I searched long for anything on vertical curves and trucks.  We had a site with a steep driveway and we needed a way to find out if trucks would bottom out on the curve.
The only thing I ever found was cross slopes on shoulders for tipping.
Conan Witzel
*Expert Elite*
sboon
Message 3 of 13 (1,232 Views)
10-15-2012 12:11 PM in reply to: witzel
Check AutoTurn Pro from Transoft Solutions for this.
From the brochure:
Generate 3D swept path envelopes with vehicle height and ground clearances
to analyze designs in a three-dimensional space. Users also have the options to
display the 3D swept path of the vehicle body or body clearance.
http://c464509.r9.cf2.rackcdn.com/autoturnpro.pdf
mnorton
Message 4 of 13 (1,218 Views)
10-15-2012 02:37 PM in reply to: mnorton
Conan,
I think the Institute for Transportation Engineers (ITE) may help you. They have several publications pertaining to design for low clearance vehicles.
Mike
www.thecivilguy.com
Civil 3D 2014 (64)
AMD Radeon HD 6900
mnorton
Message 5 of 13 (1,215 Views)
10-15-2012 02:46 PM in reply to: sboon
Steve,
Thanks for the brochure.  I requested their demo version and will post my results.
Norton
www.thecivilguy.com
Civil 3D 2014 (64)
AMD Radeon HD 6900
*Expert Elite*
jmayo
Message 6 of 13 (1,193 Views)
10-16-2012 08:33 AM in reply to: mnorton
At a minimum with a design like this I would want a profile at the top of the vehicle so I could see the clearance in profile view.
If I had a corridor I would add a vertical link and marked point to the CL extending up to the top of vehicle. I would hide the vertical link in the subassembly code.
If I did not have a corridor I would copy the FG profile and move it up to the top of vehicle.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
mnorton
Message 7 of 13 (1,180 Views)
10-16-2012 10:31 AM in reply to: jmayo
Thanks, John, but in this case I'm only interested in that the trailer undercarriage clears the top of the levee.
I've performed a fairly exhaustive search at the state, federal, and local levels for applicable guidelines but no luck so far.  I also contacted a half dozen or so manufacturers thinking there might be industry guidelines but zero there too.
The literature on AutoTURN Pro software is promising but the program doesn't include lowboy trailers.  The Wisconsin DOT provides a lowboy trailer in AutoTURN format BUT THE DEMO VERSION WON'T IMPORT VEHICLES. Sorry, I was yelling and throwing things.
I actually calculated the clearance but my formula only accounts for two axles and the clearance - not the impact of the gooseneck pivot or the other three axles.
So... at the moment all I have for certain is a drawing of a tractor and lowboy trailer that looks really cool when I rotate it around my vertical curve.
www.thecivilguy.com
Civil 3D 2014 (64)
AMD Radeon HD 6900
*Expert Elite*
jmayo
Message 8 of 13 (1,176 Views)
10-16-2012 10:47 AM in reply to: mnorton
Maybe AutoTrack can help where Autoturn did not.
http://www.savoycomputing.com/
I would still run a second profile but for the undercarriage to help identify problem areas as this is a quick estimation but it sounds like you will still need to manually draft the vehicle undercarriage line in the worse case position and manually place that along a profile. I would see if I could get a profile label to place a block of the undercarriage all along the profile. It will look ugly but you should be able to clearly see issues.
I would guess you have measurements on the tractor/trailer and or manufacturer's data to get the undercarriage line drafted.
John Mayo, PE
IDSP 2014
Valued Contributor
Buzz123
Message 9 of 13 (1,159 Views)
10-16-2012 06:48 PM in reply to: jmayo
We've use Autopath by CGS for this.
It's great for looking at both horizontal swept paths and vertical curve / vertical grade break analysis.  It comes with a selection of vehicles.
However, you can also add your own customised ones (for both horizontal and vertical anlysis).  (We've loaded our own truck towing a boat on a boat trailer for analysing boat ramp design - the custom vehicles look awesome).
When you run the software you can select a profile and it'll sit your vehicle on the profile and then run it along along the profile (use a 1:1 vertical exagerration in your profile view style). You can freeze the vehicle at any point and leave an outline on the profile if you want.
Have a look at the website here:
 (http://usa.cgsplus.com/tabid/551/language/en/Default.aspx)
Looks like there's a free trial available.
Michael
Civil3D 2012
HP Elitebook 8560w
Core i7-2820QM (2.3-3.4GHz)
nVidia Quadro 2000M 2GB
www.foxsurvey.co.nz
mnorton
Message 10 of 13 (1,141 Views)
10-17-2012 05:21 AM in reply to: Buzz123
Thanks, Michael. (I think.) Now I've got three programs to evaluate - AutoTURN, AutoTRACK, and AutoPATH!
John, I have a truck/trailer drawing to visually check for clearances but it only accounts for two axles and the bottom clearance.  I'm not sure how to model the gooseneck pivot and the other 3-5 axles or even if it's necessary. I may be way overthinking this but it's going to be tough to explain if I send a truck to the river and it gets stuck on the levee road I designed. Oh, well.  I've been thrown out of better bars than this.
www.thecivilguy.com
Civil 3D 2014 (64)
AMD Radeon HD 6900
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
