AutoCAD Civil 3D General Discussion
*Expert Elite*
245 Kudos
Post 11 of 13
Re: Calculating VC for Lowboy clearance
10-17-2012 07:16 AM in reply to: mnorton
We use Autotrack for sweep paths through projects but I have not used the vertical path routines. I have only had to estimate vertical clearance for a couple of jobs and I have done it with profiles. I would really try to get one of the software packages to help with this but in the event of that not happening...
"I'm not sure how to model the gooseneck pivot and the other 3-5 axles or even if it's necessary"
I would think the model would need to be pretty specific for the tractor trailer combos used. Different 5th wheels, different 5th wheel locations and heights, tractor trailer sizes and king pin locations should have an affect on this. A low boy will probably have a fully oscillationg 5th wheel to allow for more side to side deflection as well. I think these mount a bit higher. You should be able to measure the deflection on a fith wheel without a trailer attached. It may take a few people and be quite greasy but you should be able to see how the 5th wheel pins in all directions. Max deflection between tractor and trailer should come to light when you draft this up. You may see the front of trailer hit the tractor frame or the top/rear of the tractor frame hit the bottom of the trailer but the limits should be seen.
I would think the number of trailer axles is important to model since you could have a situation where one axle may support the entire trailer and the other two would be in the air. You would also want to monitor the rear trailer overhang and make sure that this does not hit the ground.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Distinguished Contributor
2 Kudos
Post 12 of 13
08-13-2013 05:31 AM in reply to: jmayo
John (and anyone else still interested)
We purchased AutoTrack and with some invaluable help from Mike Hutt in their UK office I now have a process in place that we've used on several projects.  I also now use the swept path feature to analyse vehicle access to all of our sites.
The program balked at using my Civil 3D profile for the vertical clearance analysis and I haven't had the chance yet to troubleshoot the issue.  I can't say enough good about the support I've received from Savoy Computing Services and I'm sure a fix is simply a phone call away.
Meanwhile, AutoTrack refused to select the profile object, so I did what any red-blooded Texan would do, I exploded the profile and everything worked just fine.  Desperate times call for desperate measures.  I had a crew in the field ready to lay some road.
Thanks for your help, John.
Mike Norton - The Civil Guy
www.thecivilguy.com
Civil 3D 2014 (64)
Windows 7 Pro (64) SP1, 16 GB
AMD Radeon HD 6900
*Expert Elite*
245 Kudos
Post 13 of 13
08-13-2013 06:08 AM in reply to: mnorton
No problem MIke. I am happy to help and I am glad you got through it all.
I also have nothing but nice things to say about the folks at Savoy. They have treated us well since 05.
Be well, :smileyhappy:
John Mayo, PE
IDSP 2014
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
