AutoCAD Civil 3D General Discussion
*Expert Elite*
Joe-Bouza
Message 11 of 30 (111 Views)
Re: Calculating side slope
03-19-2014 07:26 AM in reply to: getrekdent
Your alignment may have geometry that precludes the offset. i.e. too tight a radius or kink?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Active Contributor
getrekdent
Message 12 of 30 (111 Views)
03-19-2014 07:30 AM in reply to: Joe-Bouza
Now it's doing this.... which is awesome :smileysad:
*Expert Elite*
Joe-Bouza
Message 13 of 30 (109 Views)
03-19-2014 07:31 AM in reply to: getrekdent
was your alignment created from objects or drawn with the layout tool bar?
I suspect objects.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Active Contributor
getrekdent
Message 14 of 30 (102 Views)
03-19-2014 07:41 AM in reply to: Joe-Bouza
I loaded my survey points, Created a surface, Created a feature line with elevations, Loaded quick profile then exported to Land xml file, Inserted the land XML file which dropped the alignment along the line, then set my start point from the alignment. All I had to work with was a .shp file from a survey company. This is for a pipeline bid project so information is very limited
Active Contributor
getrekdent
Message 15 of 30 (101 Views)
03-19-2014 07:46 AM in reply to: getrekdent
I used the "3dpoly, 'pn, 1-4333" command as there are 4333 points in my survey file
Active Contributor
getrekdent
Message 16 of 30 (92 Views)
03-19-2014 08:13 AM in reply to: Joe-Bouza
I guess what I need is the `Z`` Coordinate 7 meters to the left and 7 meters to the right of these survey points.  My employer would me like to manually calculate the slope.  Of the side hill sections.
*Expert Elite*
Joe-Bouza
Message 17 of 30 (70 Views)
03-19-2014 07:44 PM in reply to: getrekdent
Well, you have confused the heck out of me. You have no surface only points along alignment, you have a surface? Which is it?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Active Contributor
getrekdent
Message 18 of 30 (59 Views)
03-20-2014 07:08 AM in reply to: Joe-Bouza
Ah Sorry! I have a surface points along my surface and an alignment.
*Expert Elite*
Joe-Bouza
Message 19 of 30 (56 Views)
03-20-2014 07:21 AM in reply to: getrekdent
That does not clarify anything. I appologize but is english not you first language? I have lost track of what you are trying to do?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Active Contributor
getrekdent
Message 20 of 30 (48 Views)
03-20-2014 07:45 AM in reply to: Joe-Bouza
I appologize,
I will outline the steps I have taken please correct me if I am wrong ( I am new to Civil 3D and have been tossed into this):
1. Import the survey points from .xyz file
2. Create surface from the points file
3. Create feature line along points and a quick profile from this line
4. Export the land xml file containing the quick profile then Import the land xml file back into my drawing which automatically creates the alignment along my survey points.
What I am looking to do is find the side slope along these survey points to calculate the volume of material we will be required to remove in order to build the Right of way for this project,  The project spans over multiple mountains with severe vertical and side slopes which we are required to cross.
I really appologize I am not meaning to frustrate or confuse anyone. Question.png
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
