Good Day!
I have created an existing ground profile of a surface I will be working on which runs through the mountains, Is there a way I can plot points along my existing ones say two meters above and two meters below the center line then create a profile or calculate slope between the two points?
Solved by Joe-Bouza. Go to Solution.
@getrekdent wrote:
Good Day!
Probably, but you can plot a profile view for your alignment:
1. create a FL or 3dpoly from you points, copy, raise lower and project to the view.
2. create a point file of station offset and edit in excel to create a profile input file
Your Name
Your Name
Ok If I understand correctly, you have a line if points along your alignment of existing and you are wanting to see a cut and fill windowe Hopefully the points are sequential.
Create a FL with the transparent command for point numbers (if they are not too numerous you can simply draw the FL) . You should get a FL from one end of the alignment to the other. Now you can make two copies for above and below. you do this with the copy to site command on the FL. one copy to -xmeter and one to +xmeters. you'll have 3 FL now.
1. Create a profile view for the alignment, adjust the elevation tab to be in the range of known point elevations. You will now have a blank profile view.
2. Qselect all the FL's (properties dialog filter all FL)
3. home tab>> profile views>> project to view ( accept objects elevation)
4. draw your layout profile betwee the cut and fil line
Your Name
Your Name
Thank you that is what I was looking for 🙂
One more question.. sorry, I am trying to create an offset alignment now, I want it offset 7m each side of centerline. The offset will take effect on the left side but nothing happens on the right side? Is there some setting I am possibly missing?
Your Name
Your Name
You got this? Or are you looking for a profile?
Your Name
Your Name
"No. of offsets on Right" options is zero. You should set it 1. It means you can create only one offset for this side.
Yup! This is the one! I don't know what it's issue is..
Your Name
Your Name
Now it's doing this.... which is awesome 😞
Your Name
Your Name
I guess what I need is the `Z`` Coordinate 7 meters to the left and 7 meters to the right of these survey points. My employer would me like to manually calculate the slope. Of the side hill sections.
Your Name
Your Name
@getrekdent wrote:
Ah Sorry! I have a surface points along my surface and an alignment.
That does not clarify anything. I appologize but is english not you first language? I have lost track of what you are trying to do?
Your Name
Your Name
I appologize,
I will outline the steps I have taken please correct me if I am wrong ( I am new to Civil 3D and have been tossed into this):
1. Import the survey points from .xyz file
2. Create surface from the points file
3. Create feature line along points and a quick profile from this line
4. Export the land xml file containing the quick profile then Import the land xml file back into my drawing which automatically creates the alignment along my survey points.
What I am looking to do is find the side slope along these survey points to calculate the volume of material we will be required to remove in order to build the Right of way for this project, The project spans over multiple mountains with severe vertical and side slopes which we are required to cross.
I really appologize I am not meaning to frustrate or confuse anyone.
