Hi, so the thing is that i have to make vertical plan of the football stadium (heights plan). I have existing ground, i have subgrade. So if i calculate earthworks its gonna be fine. But i need, to excavate existing soil, subground, asphalt and all that stuff is in different places. I tried like raise lower surface, but its only for like one place, if the excavations is in few, i cant do anything. So maybe u have some advices how to make that. Thanks in advance.
Create a dynamic subgrade (see link below) for exisitng conditions and another for proposed (you have this already) and then compute the volume of these two. The stripped EG and the proposed subgrade.
John Mayo
Also have a look at this as it seems to be pretty similar to what you've described.
http://forums.autodesk.com/t5/autocad-civil-3d-general/large-paving-area/m-p/5307883#M259118
Don Ireland
Engineering Design Technician
neilyj (No connection with Autodesk other than using the products in the real world)
I really like this technique but the upfront overhead makes me wonder. If you want it for sections and profiles great but to go to that effort for net earth work calcs? If you have the area polygons you have the volume of the subgrade and your done: increase the fg vs eg cut value for the net earth work. I've been showing this picture for years, and now we can do it in civil3d. thats great, but a lot of work. See (-F)=(C) therefore everything below fg increases cut regardless.
Joe Bouza
Yes it is a lot of upfront work and Civil should be able to compute this with ease (another package that I use has no difficulty with this sort of calc).
Whilst your method work for the total net cut/fill, more often than not I need to know the location of the cut and fill in order to devise an earthworks strategy (e.g, mass haul) and identify constraints in moving muck from the cut area to the fill area.
Opps
Wrong link.... Neil posted the correct link.
Here's the front page for the AU class.
John Mayo
Joe Bouza
Joe Bouza
