hello. i have cross-sections and calculate wolumes but on cross-sections it does not show full Rip Rap section. for example i can show you. what will be reason?
Mziani,
Похоже, ваш Rip Rap Область не Дневное освещение. Проверьте свой сборочный узел. Вы можете разместить свой рисунок?
Looks like your Rip Rap Area is not Daylighting. Check your Subassembly. Can you post your drawing?
Dave
Dave Stoll
Las Vegas, Nevada
Mziani,
Пожалуйста, пост свой рисунок в качестве вложения. То, что, как другие здесь смогут посмотреть на чертеж.
Please post your drawing as an attachment. That way others here will also be able to look at your drawing.
Dave
Dave Stoll
Las Vegas, Nevada
Mziani,
Этот форум позволит вложения до 5 Мб, я думаю. Если это больше, чем, то, возможно, вы можете W-Block первой необходимости, чтобы получить размер файла вниз. Площадь Rip-Rap не естественное освещение, поэтому мы должны видеть, если поверхность является проблемой.
This Forum will allow attachments up to 5 Mb, I think. If it's larger than that, then maybe you can W-Block the essentials to get the file size down. The Rip-Rap area is not daylighting, so we'll need to see if the surface is the problem.
Dave
Dave Stoll
Las Vegas, Nevada
thank you. but it is very big file 8mb and does not attach here.. i can give you my email and there i will show you
Mziani,
ОК, прислать их мне. Используйте свое имя ФорумGmail.
OK, send it to me. Use my Forum name @Gmail.
Dave
Dave Stoll
Las Vegas, Nevada
Mziani,
Your rip-rap2 Corridor is targeting the Rip-Rap2 Offset Alignment, not daylighting the Final OGL Surface. So it's cutting off your Rip Rap.
Dave
Dave Stoll
Las Vegas, Nevada
Mziani,
Another thing I noticed was that I don't even show the rip-rap area of the section in your screenshot.
Dave
Dave Stoll
Las Vegas, Nevada
Mziani,
Corridors are not my strong suit, so I'm not sure how best to fix things up. I'd start here and figure out what's missing and what needs to be updated:
Dave
Dave Stoll
Las Vegas, Nevada
