Civil 3D Forum
Calculate the volume with both sides of uneven rock surface in excavation pit
2 REPLIES 2
2angkeankeong
554 Views, 2 Replies
At my job site, they is about 20meter height of uneven rock surface in the excavation pit.
To calculate the volume ,I need to include this uneven rock surface wall.
For doing so,The sharp edge will displays in the cross section.
Because the uneven surface, I cannot create the surface with normal step.The TIn line will joins horizontally,not in vertical direction as is intended.
So how to solve it?
Thank in advanced.
AutoCAD Civil3D 2014
Inter(R)Core(TM) i7-3770 cpu@3.40GHZ
RAM 8.00GB
64-Bit window7
QuadroK6000
2 REPLIES 2
sboon
in reply to: 2angkeankeong
Civil3d surfaces cannot have vertical TIN lines, and cannot have overhangs so it may not be possible to calculate volumes using the data you have.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
in reply to: sboon
so how do you do it?
Rail Community
