I’ve designed a road using an alignment & corridor. I’ve also created a surface from the corridor and obtained an overall cut/fill quantity. Is there a simple way to calculate quantities between 2 alignment chainages?
I need to calculate the cut/fill quantities every 300 feet.
Solved by wfberry. Go to Solution.
If you already have a TIN Volume Surface, you can create a polyline around that surface and calculate bounded volumes. Of course, you'd have to draw the polyline accordingly between the desired stations.
