I mean real slow....what used to take 8-10 seconds to start C3D2014 to Drawing1 now takes 90-120 seconds. When I can finally click the A icon in upper left corner it takes 10-15 seconds before I can select a recent dwg to open. Once I do select a dwg, the dwg that took ~5 seconds to load previously now takes ~90 seconds.
I have run a repair install on C3D2014 with no change in these times. I've run ProcessMonitor to see if there's anything obvious and I sure don't see anything. Does anyone else with both these versions installed see the same type of slowdown?
Solved by Jeff_M. Go to Solution.
am I right that your 2015 video with hw-acceleration is slower than without hw-acceleration?
- alfred -
The same happens with 2013. It’s faster with hw acceleration off. But the quality of the view in both versions isn’t good enough without it.
In both cases 2013 is faster in a point that you easy understand it.
I want now to wait if anyone else confirms that. At least I never had a quality difference between hw-accerlation on or off.
And it's very untypical that your graphics is slower with hw-acceleration on (compared to faster when hw-acc off) as long as you are in a rendered style and not in 2D-wireframe mode.
Can you describe what you mean by quality difference? Where do you see anything displayed with less quality when hw-acc is off.
And just as an idea: if it has to do with texture maps, then it might depend on texture map compression, but in any case, a texture map is used with command _RENDER, not important on the display IMHO.
- alfred -
I'm having the opposite affect. I just installed IDSP 2015 this morning and C3D 2015 opens much slower than 2014. Both are on the same SSD drive. It does seem like the interface for 2015 is faster, but I've also had it crash on me 3 times doing basic things like create a new, blank drawing using the OOTB blank template then close that drawing. I'm not even importing any workspaces from older versions.
