Civil 3D Forum
C3D2012 DGM
2 REPLIES 2
office
292 Views, 2 Replies
C3D2012 DGM
I tried to create user defined contour line, but the function hides (see picture).
This Analysis is only working by heights, anything else hides. Is there already some fix available?
Christoph
C3D2012
DGM Analysis
Win7 64bit
HP z400 Workstation
ATI FirePro V4800
C3D2013
2 REPLIES 2
AlmasSuljevic
in reply to: office
Hi Chritoph,
I would suggest staring with repair of install from Control Panel. Other possibility may be a display issue. Do you see any options if you hover over the area where the options should show up?
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
office
in reply to: AlmasSuljevic
Repair already tried, but not fixed the issue. I'm able to reproduce this on two different clients. By trying via TAB it jumps directly from the legend-options to the preview (compared with c3d2011). Some other workarounds?
Win7 64bit
HP z400 Workstation
ATI FirePro V4800
C3D2013
Rail Community
