I tried to create user defined contour line, but the function hides (see picture).
This Analysis is only working by heights, anything else hides. Is there already some fix available?
Christoph
C3D2012
Hi Chritoph,
I would suggest staring with repair of install from Control Panel. Other possibility may be a display issue. Do you see any options if you hover over the area where the options should show up?
Repair already tried, but not fixed the issue. I'm able to reproduce this on two different clients. By trying via TAB it jumps directly from the legend-options to the preview (compared with c3d2011). Some other workarounds?
