Civil 3D Forum
C3D10 to C3D11
10 REPLIES 10
Message 1 of 11
wincocadd
689 Views, 10 Replies
C3D10 to C3D11
Hello All I have question for all of you greater minds.
Winnebago county is in the infancy of creating our styles and set-up and to save time we thought we might use WisDOT, I sent an email to their Engineering section as to how best to implement their stuff and I got back this response One important item to note is our setup is for Civil 3D 2010, and much of it will not be compatible for C3D 2011.”  My question is are you familiar with what they have done and why it wouldn’t work well with C3D 2011, or just in general why wouldn’t a 10 setup work in 11?
Best Regards
Andrew Rose
Civil Engineering Specialist
Winnebago County Highway Department
ph: 815-319-4037
10 REPLIES 10
Message 2 of 11
mathewkol
in reply to: wincocadd
I think what they are probably meaning to say is that 2011 files are not compatible with 2010.  You can open any 2010 file using 2011 and eveyrthing will work well.  But if you edit that file in 2011 and send it back to them, they cannot use it EVER!
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 3 of 11
Our FDOT C3D2011 kit was brought forward from our 2010 kit without problems. We did recompile all of our sub-assemblies for 2011.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Message 4 of 11
Michael
Did your organization recompiled the sub-assemblies due to a language problem....? VBA vs .NET?
Message 5 of 11
We recompiled with the VB .NET target set to "AnyCPU" so they would work on 32 & 64bit C3D 2011.
Mike Robertson
Message 6 of 11
Sinc
in reply to: michael.robertson
Did you have problems with the View Cube being canted at a weird angle in WCS in any drawing created from that template?  Or do you have the View Cube turned off?
Sinc
Message 7 of 11
Jeff_M
in reply to: Sinc
I haven't seen this problem using my 2010 DWT. The only drawing I have seen this occur with was supplied by someone else.
Message 8 of 11
michael.robertson
in reply to: Sinc
Which template are you refering to?
Mike Robertson
Message 9 of 11
Sinc
in reply to: Jeff_M
Very strange...
Our template was actually started in 2009 (I think), and brought forward through two versions...  I wonder if that has anything to do with it?
I've taken to just turning off the view cube and ignoring it...  That's the "easy fix".  🙂
Sinc
Message 10 of 11
michael.robertson
in reply to: Sinc
The view didn't accidentally get rotated somehow did it? (Ours was accidentally rotated at one point).
Mike Robertson
Message 11 of 11
Sinc
When the drawing is set to WCS, the view cube is "canted".  When set to "Top" view, it looks fine.  No idea what causes it.
Here's what it looks like in WCS:
1650i2C39C74BE4953E8B
And here's what it looks like in Top View:
1652i872EB705D757B5FB
It works fine in Top View.  However, if we're in UCS and hit "Top" on the View Cube, it rotates our drawing to a twisted orthogonal view.  So the View Cube is useless in WCS.  It works fine in Top View, but it means we have to switch back to Top view every time we switch back to WCS, which is annoying.  So eventually I just turned off the view cube and have been ignoring the issue.
Sinc
Rail Community
