Civil 3D Forum
C3D to HecRAS export issues
8 REPLIES 8
Message 1 of 9
tdinkins
7492 Views, 8 Replies
I am trying to use the "Export to HEC RAS" output tool in C3D 2011 and have come across a strange problem. I know that CAD and HECRAS view alignments in opposite directions (CAD - stationing from upstream to downstream, HECRAS - stationing from downstream to upstream), and understand the process of utlizing "GIS Tools" within RAS to reverse the flow direction. However, I am having a issue with georeferencing the alignment and cross sections during the "Import Geometry Data"_"GIS Format."
Once I click the "Finished-Import Data" within the Import Geometry Data dialogue, my stream alignment does not extend all the way to my most downstream cross section, and I'm getting an error message saying...
"Some of the cross sections on the schematic are drawn outside the reach bounds. This indicates that the river/reach network has not been georeferenced and/or all of the cross sections have not been georeferenced."
(see screen shot attachment below)
The two cross sections that are outside the reach bounds show up in the profile view and cross section editor view.
If I ignore the error message and click "Remove GeoReferencing" I lose the ability to "flip Coord Order" of the reach lines and cut lines. This is problematic becuase I can't get my reach stationing or cut line orientation fixed.
If anyone has come across this problem and knows a fix/work around, your input would be greatly appreciated.
thanks,
TC
8 REPLIES 8
Message 2 of 9
Wilbers2013
in reply to: tdinkins
Will it be possible to post a drawing?
Willie Wilbers
AutoCAD & Civil 3D 2014
ArcGIS 10.1
Message 3 of 9
Wilbers2013
in reply to: Wilbers2013
Check if your alignment and/of some of the cross-sections goes over the edge of the surface.  We have had problems with that.
Willie Wilbers
ArcGIS 10.1
Message 4 of 9
jmayo-EE
I find Robert Stelmans River Tools better suited for c3d to hec ras and back.
John Mayo
Message 5 of 9
jmayo-EE
If ur interested
http://www.rsteltman.com/
John Mayo
Message 6 of 9
tdinkins
I was able to solve the problem.
Apparently something was funky with my alignment. I solved it by creating a copy of the alignment by a simple 1ft offset away from and the a 1ft offset back. I used this polyline to create a new alignment/sections and bingo!
Who knows what was screwed up with the initial alignment...
TC
Message 7 of 9
EliteCataphract1
That worked for me too!  how strange
Message 8 of 9
ChrisRS
I'm glad you found a work around. Sometimes inexplicable things happen in Civil 3D and it is best to figure out a way to just move forward. Doing things over is sometimes just a part of the C3D experience.
Thanks for coming back and posting your work around and marking it as a solution,
That is very useful for others in the user community
Christopher Stevens
Message 9 of 9
evaneviecroft
I had the same issue and it was caused by my channel centerline alignment and section lines not being referenced to the correct surface.
Rail Community
