I am using C3D 2014.
I just tried to dimension between lines and the dimension command was prompting me to select the object line instead of allowing me to pick a point on the screen. The same for selecting a surface and setting a spot elevation label, I am prompted to select a point instead of a screen location. What setting have I changed to cause this performance?
Solved by Jay_B. Go to Solution.
This is awhat I am prompted when applying a Linear Dimension:
Command: _dimlinear
Specify first extension line origin or <select object>:
But the <select object> is inactive and I'm able to click a point on screen for ends of dimmension to be placed.
As for the Spot Elevation label here's the prompts:
_AeccAddSurfaceSpotElevLabel
Surface: EG
Select a Point:
AFAIK, in both cases, it's the same as you've described here.
Ok, It must be that I am not getting the snap icon, just a cursor box. So if I select nearest, the snap symbol for nearest does not appear. It appears different from what I am used to, some setting has changed. Is there a setting for the snap icon?
Options > Drafting Tab > Auto Snap Settings > check / uncheck here as desired ?
