Valued Mentor
gccdaemon
Message 1 of 5 (793 Views)
C3D Scale List in Registry
793 Views, 4 Replies
02-28-2011 09:39 AM
I'm having a problem getting my custom scale list to work correctly when I reset it. In the civil3D scale list area (HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R18.1\ACAD-9000:409\AEC\6.5\AecBase60\Scales\) What is the difference between the "FEET" and "INCHES" sections? It appears to me that only the "INCHES section is being inserted into my drawing despite what my units are set to. Are the units even linked to the these sections? Anyone with information on this would be greatly helpful.
Andrew Ingram
Civil 3D x64 2012
Win 7 x64 Ultimate
I7 3820 (3.6ghz quad core with HT)
32gig RAM (Corsair XMS3 4x8g)
Intel x z79 mobo (BOXDX79TO 2011 socket)
Radeon HD 7850 2gb GDDR5
Perhaps "-DWGUNITS" will get you there.
Valued Mentor
gccdaemon
Message 2 of 5 (744 Views)
Re: C3D Scale List in Registry
03-01-2011 05:46 AM in reply to: gccdaemon
I still can't figgure this out, but I did notice that there is some reference to feet and inches that must be the factor. A default autocad based file defaults to the inches section, and one of my files with a few civil 3D alignments uses the feet section. I'm not sure if there is a place to set the units, but it doesn't appear to be linked to the drawing units or insertion units. If ANYONE can help, please post!
Andrew Ingram
Civil 3D x64 2012
Win 7 x64 Ultimate
Jeff_M
Message 3 of 5 (737 Views)
03-01-2011 06:22 AM in reply to: gccdaemon
Distinguished Mentor
andrewpuller3811
Message 4 of 5 (714 Views)
03-01-2011 12:39 PM in reply to: gccdaemon
It depends on the source drawing settings.
If you template units are set to feet the drawing created from it are going to have their units set to feet and use those scales initially. If you then change to inches, then you will get a mix of the 2 as the feet scale will have been referenced and then the inches scales will be added.
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
Valued Mentor
gccdaemon
Message 5 of 5 (692 Views)
03-02-2011 05:53 AM in reply to: Jeff_M
That was the key. Thanks Jeff.
Andrew Ingram
Civil 3D x64 2012
Win 7 x64 Ultimate
