Civil 3D Forum
C3D Running Really slow
18 REPLIES 18
Message 1 of 19
getrekdent
12013 Views, 18 Replies
Hey,
I'm Runing C3D 2014,  It's just started running really slowly.. It takes me nearly an hour to create a quick profile from a polyline. Any suggestions on settings or do I have a bad install.. I`m sure my computer can handle this.
Alienware MX17
Intel(R) Core i7-4930MX CPU at 3.00 GHZ
16.00 GB Ram
Windows 7 Ultimate 64 Bit
Ge Force GTX 780M Graphics card with 4.0 GB RAM
When I open task manager it only shows my 4.2GB of RAM Being used while processing which doesn`t make sense because it takes flipping forever to load anything!! Any Help is appreciated!
BoXx ApeXx S3 Workstation - 64 GB Ram
i7 Overclocked to 5.1GHz - Nvidia Quadro P6000
18 REPLIES 18
Message 2 of 19
nwray
in reply to: getrekdent
Is this happening on multiple drawings or just on one?  Not sure if it would cause the slowdown you noticed, but have you tried clearing out your temp files?
Norm
GIS Specialist
BOXX Technologies APEXX 2 2402 Workstation
Intel Core i7-6700K @ 4.4 GHz
32 GB RAM / 500 GB SSD
NVIDIA Quadro M2000 Graphics
Windows 7 Pro 64 bit C3D 2017
Message 3 of 19
getrekdent
in reply to: nwray
It is on one drawing, I have recreated it twice now and when I go to create a profile it takes close to 20 minutes, when I send the profile to .xml and then try to reload the file back in it takes hours... I have 14555 survey points over 430km along a pipeline Right of way I am trying to gather information for.  I know the amount of information is high but is there anyway I can speed the process upÉ
Thanks!
Message 4 of 19
getrekdent
in reply to: nwray
Dow do I clear my temp filesÉ
Message 5 of 19
Jay_B
Default temp folder location for Win7 is here:
(Note Appdata is a hidden folder by default in windows)
C:\Users\Username\AppData\Local\Temp\
Just delete everything it will let you while C3d is closed.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 6 of 19
Jay_B
Sounds like quite the project.
What is the dwg file size?
and how is your workflow set up what's in this file besides the points?
Do you have multiple Civil 3d source dwgs, or is everything in one file?
Are data shortcuts being used?
C3D 2018.1
C3D 2016 SP4
Message 7 of 19
getrekdent
in reply to: Jay_B
Thank you I will try that! 🙂
Message 8 of 19
getrekdent
in reply to: Jay_B
It is and it`s far above me.. I received a Gis which I was able to extract the xyz coordinates out of then load them into C3D as a points file. The information I have received is bare minimum, I just need to calculate all my slopes offsets and side bends. I am nearly there but my computer is not handling it well now that I am getting further into it. I have everything in one file, I guess my next step would be to break it up into multiple dwg`s.É
Message 9 of 19
jfengineering
I had a similar problem with one of my files.  It turned out to be point groups (8 of them) that were in the file, but were from another project.  I guess C3D was going through each group trying to reconnect or search for the points or something.  Once I deleted the bad point groups, the file worked just fine.  Hope this helps, best of luck.
JF Engineering, PLLC
Civil3D, Current/Win 10 Pro
MSI MPG X570/AMD Ryzen 5 3.6 GHz
EVGA GTX 1650, 4GB
1TB Samsung 970 M.2
16 GB DDR4 3200MHz RAM
2x ViewSonic VX2458 24in Monitors
Message 10 of 19
neilyj666
You could also try WBLOCKing to a file and INSERTing to a new file created from your template
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 11 of 19
getrekdent
in reply to: neilyj666
How would I do this, Sorry I haven't worked In C3D a whole lot... Could you
please eplain the theory a bit?
Message 12 of 19
jfengineering
To purge unused point groups, or anything like alignments or surfaces, you will need to go into Toolspace, (left button on home tab) Prospector tab -> go down to Point Groups and click on it and see if there are point groups listed that have yellow tags next to them.  Select the group and right click and select delete.  Same goes for profiles, alignments, and surfaces.  Try updating the yellow tagged items first, but if they update they shouldn't be slowing the project down.  If you can not delete the point groups, and they have a small triangle in the upper right corner, next to thier name, it is because the point group (or other entity) is being used in the definition of another object.  Example here would be a point group can not be deleted because it is used in the definition for a surface.  Or a surface can not be deleted because it is used in a profile.
EVGA GTX 1650, 4GB
1TB Samsung 970 M.2
Message 13 of 19
getrekdent
in reply to: jfengineering
Okay I have one point group category (All Points) and yes it does have a yellow tag in the corner, What can I do with that?
Message 14 of 19
getrekdent
Is there a way I can remove points that are within a certain distance of each other through the command line?
Message 15 of 19
jfengineering
All points will always be there as long as you have points in your file.  You should be able to right click on this if it has a yellow tag and select Update from the drop down list.
Not aware of a method to erase points within a certain distance of each other without writing a LISP routine.
EVGA GTX 1650, 4GB
1TB Samsung 970 M.2
Message 16 of 19
wfberry
There is an easier and quicker way to get to the temp files, in the Windows 7 START menu's search box enter:
%temp%
Bill
Message 17 of 19
drenaud
remember this post? : )
I'm also experiencing big time delays in performance in C3D, but not with one file, but all files. I am wondering if it is connected to point groups. I checked just now and sure enough there were point groups that couldn't be found because the data shortcut folder had defaulted to the last project used. this is a brand new drawing. can you describe how, or if?, i can have C3D set the working shortcut folder to the current drawing (project - i use a template to create the same fiolders in each project) when i start a new dwg? it never occurs to me to check the data shortcut folder on starting something. i want to not have to.
thanks
david
C3D 2015
Message 18 of 19
jfengineering
in reply to: drenaud
Unfortunately, as far as I know, you have to manually change to the correct project.  It is a hastle and I forget to do it too.  I still struggle with selecting the correct 'Project folder'.
EVGA GTX 1650, 4GB
1TB Samsung 970 M.2
Message 19 of 19
webmaster
in reply to: Jay_B
I had a user with performance issues in Civil 3D 2014 and clearing the appdata/temp directory worked for us. Thanks!
Rail Community
