does anyone know what to put in the override box to start a second line of text? its autocad 2013
Solved by joeb. Go to Solution.
Solved by jmayo-EE. Go to Solution.
Not running 13, but in earlier versions \P would add allow additional lines of text and \X would place the next line of text below the dimension line. You can use these codes in combination too if you would like, for example, to have 2 lines of text above the dim line and 2 lines of text below it.
