Hello All,
I am working with a goverment agency and we have hired two cosultants to work on a projects. They are using data shortcuts for surfaces, alignments and pipe networks. When they delivered C3D files to us get our reviews, (they burned the dwgs on the CD) all surfaces and alignments are broken.
My question is:
1) How do I repair those broken C3D objects?
2) What should i request the consultants to provide us so that when I open these drawings at my end, the surfaces are not broken.
Thank you very much!
SeatlleCAD,
Sounds like they are using Microstation and exporting out as C3D. But if not, tell them to export a DEM. This might help you on your end when you import.
If they supplied the _Shortcuts folder, you should be able to set your Data Shortcuts working folder to the folder directly above _Shortcuts. If they didn't provide it ask for it.
Mark Green
Working on Civil 3D in Canada
It is a 60% review at this time. But almost Civil drawings are missing surfaces, alignments, and pipe networks. I don't want to tell them to export all the reference drawings. It will make a lots works for them.
If I request them to sent us their shortcut directory structure, and set up exactly at my end, Will data shortcuts be fixed when opening a drawing?
2) What do you recommend when we receive final drawings?
Thanks a bunch!
Caveats may apply depending on how they are setup, but generally speaking if the shortcuts work fine on their end, they have a clean workflow (all C3d source dwgs in 1 folder) etc. you should be fine just mapping the _shortcuts folder AFAIK. I copy projects off out of office servers here locally quite often and the Data shortcuts come through just fine once mapped.
Mark Green
Thank you very much for your help!
How to download this Data shortcuts editor? I have standalone C3D 2012.
If you ask them to etransmit all of their files and select the "Place files in one folder" option, there should be no mapping required. If so, then use the data shortcuts edittor found in thw windows Start menu.
We require the CAD drawings (often not C3D because a lot of consultants use Microstation), a PDF of the full set and a hard copy for the files. We often have an item for the consultant to produce all the hard copy to be used on the job.
Allen Jessup
Allen Jessup
CAD Manager - Designer
