Unequal ROW widths and sidewalk location at Intersection. Curb Fillets(Returns) connect properly. However since the ROW's are different widths the sidewalks do not connect. What/How should I go about making this transition. Newbie at C3d long time designer/cadd operator.
Solved by david.zavislan. Go to Solution.
A sample? Post your drawing or a screenshot.
Attachment missing.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Can't get Curb Fillet (Curb Return) assembly to connect sidewalks of two different streets with different offsets (distanct between back of curb and edge of sidewalk) to connect. Please see image below .looking for directions/methods to make the sidewalk alignments connect.
Draw a polyline that transitions from the front of walk from one road to the other.
Edit the transitions for the curb return region of the corridor. Assign the polyline to the "Target Alignment of Inside Boulevard Width" target for the sidewalk subassembly. I am assuming that you are using the UrbanSidewalk subassembly.
Thanks for the reply, However can you point me to a link on setting the polyline as a target. Can seem to make that work for the sidewalk. Thanks.
