Help.... I can't see my crosshairs if I click into model space from a vport.
Same thing with selecting by window.
Apparently the color of the crosshairs are white (background is black) Tried changing to yellow, but didn't change anything.
I am assuming there is a setting I have missed.
Solved by brian.strandberg. Go to Solution.
I have seen this. Try LINESMOOTHING off.
Hope this helps.
I have also seen the LINESMOOTHING ON cause general stability issues with some users. And I kinda like the jaggedy lines anyway.
