Civil 3D Forum
C3D 2015 trusted file locations
3 REPLIES 3
ReneeClough
1767 Views, 3 Replies
Our office has mutiple CAD users.  Some on Civil 3D and some on vanilla AutoCAD.  To keep things standard we have put things like linetypes, pen tables, etc on the network and directed all the CAD installations there.  One user is having trouble with messages about "An executable file was found outside of the specified trusted locations".  We have tried adding the Z drive (the network drive where all the standardization files are saved) to the trusted locations of the option dialog, but the problem persists.  We have also tried the security settings suggested in
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-A....
I'm not sure what the significance of the messages is or how to make them go away.  It seems odd that only one person in our office is having the problem.  I've attached a file with screen captures of the messages that pop up.
Any suggestions or thoughts are greatly appreciated,
Renee
3 REPLIES 3
mathewkol
in reply to: ReneeClough
You need to specify the actual folder path, not simply the drive, if you haven't done so already.
You can turn the feature off with the secureload variable.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
neilyj666
You can also type 3 periods/full stops e.g Z:\Autodesk Support\... to allow all files and folders down the folder tree to be accessed
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
mathewkol
in reply to: neilyj666
Sweet, @neilyj666 !  I did not know that one.  Kudos 🙂
Matt Kolberg
Rail Community
