Hi All,
Working with pipe networks in 2015 for first time (have worked with previous versions with no problem)
When I create or edit a pipe network using the Network Layout Tools toolbar, the Draw Pipe & Stuctues Button and dropdown doesn't work, as well as the delete pipe network object, pipe network vistas, and undo buttons are greyed out.
The template was originally created in C3D 2014.
I hesitate to do a repair because everything else has been working fine.
Anyone else run into this problem?
This was installed using the IDS Premium Suite 2015.
Walter
Hi Matt,
Yes, I saved and closed the drawing and reopened it, the toolbar works completely now.
No custom parts.
Walter
