Hello, I have W7 64 SP1, ASUS P9X79 PRO Rev 1.xx motherboard, i7-4930K CPU, 16 GB ram, Nvidia K2000 graphics card and I am having graphics issues with C3D 2015. I have 2 30" dell 3007WFP monitors with DVI connections. I have a dell DP to DVI adapter for the DP to DVI conversion on the second monitor. But, even when I only run one monitor from the DVI port on the graphics card, I still have the same problems. I have tried all the available drivers for the graphics card with HW Acceleration both on and off- See notes at end for the results of these tests. I have done a complete uninstall and re-install of the graphics drivers and C3D 2015 and removed all autocad folders and registry entries.per:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-... I have used C cleaner and a graphics driver cleaner to cleanse the system. I re-installed with MS security off. Still the same problems. The problems are as follows: Generally, many dialog boxes do not populate with text or graphics until I click on them. When you can't see the OK or Cancel buttons, this is a problem. When I select a points file to import, the file name and file type fields stay blank until I click on them. In point file export, the choice for point group is greyed out and does not register a check mark even after clicking on it. If I try to edit a note made with annotate/note/add, I have to hit buttons twice to get a response like delete or space, and then I get two spaces or deletes. Selecting custom scale in the pull-down often crashes the program as does scalelistedit. Another regular problem is points groups hierarchy does not show changes in order when I hit the up down buttons, until I click on the field in the dialog box.. I could go on, but that is the sort of problems I am having. Is anyone else having these problems? Does anyone have a solution? Could this be a bad windows 7 installation? Below are my notes from my tests of the drivers: /////////////////////////////////////// 334.95 HW acc off note editing does not work and box is blank until I click on the field. Each edit must be enforced with another keystroke, or click on the black field to get the previous entry to display be it a space, or a letter, or a deletion. same with HW acc on //////////////////////////////////////// 334.67 beta with HW acc - same problems 334.67 beta HW acc off works better Notes edit works occasionally. generally the display for the text being edited shows, but the editing is almost always troublesome as with the other drivers. Also, as with the other drivers: Points insert from file does not populate until I click on field. Points groups hierarchy does not show changes until I click on the field. Points identity does not work from points creation tools - cannot edit any fields - but does work form settings/points/commands ////////////////////////////////////////////////////// 333.11 same as 334.95 with HW acc on or off //////////////////////////////////////////////////////// 332.76 same as 334.95 with HW acc on or off //////////////////////////////////////////////////////////////// 332.50 same as 334.95 with HW acc on or off ///////////////////////////////////////////////////// autocad certified 332.81 same as 334.95 with HW acc on or off ///////////////////////////////////////////////////////////// 321.01 with HW acc on points editing worked once with HW acc - then not after that points groups hierarchy does not show changes until I click on field. points insert from file does not populate until I click on field with hw acc off points insert from file does populate points goups hierarchy does not show changes until I click on field. note edit does not work delay and needs double entry to get result
