I think I've found a bug. Whenever I try to copy a surface slope label C3D fatal errors. This happens with the running OSNAPs on. It does not happen with OSNAP off. Has anyone else run into this problem?
EDIT: It's not just OSNAP, it's any snap that causes it. I tried creating new labels instead of copying an existing one and was able to make about 3 before C3D crashed again. So far I've submitted about 10 CERs.
Rick Jackson
Survey CAD Technician VI
I just created four or five labels on my surface and all worked. I then grabbed all the labels, copied and pasted to another location several time and no crashes (The surface is a data shortcut)
neilyj (No connection with Autodesk other than using the products in the real world)
@Anonymous wrote:
Is the surface a dref or xref?
It's a DREF surface. Just two days ago I made about 25 of them without problems. Then yesterday I couldn't make any copies and only about 3 at a time before C3D would crash. I restarted C3D and it still happened. I then restarted the computer and it still happened. I ended up using the corridor section editor to get slopes and having to write them down since it's impossible to label this drawing.
I'm stumped as to how I can cause a crash every time, yet never had the problem until yesterday.
I sure you have tried but I'll say it anyway. AUDIT
If the drawing isn't too awful busy, I would recreate it if the audit didn't work. (depends on your situation)
Rick Jackson
@Anonymous wrote:I sure you have tried but I'll say it anyway. AUDIT
Yeah, I've done audit. It never finds any errors. This happens to be my corridor drawing and I'm supposed to have it finished by tomorrow morning so the surveyors can go stake it out. Recreating the drawing is a no go. 😞
