Civil 3D Forum
C3D 2014 Pressure pipe issues
4 REPLIES 4
628 Views, 4 Replies
We are trying to use Pressure Pipes  2014 in a production environment and have some questions\issues.
1) When using data shortcuts, the pipe profile is different from the source profile ie when generated from a surface that has a vertical curve, the DS profile is not smooth but is shown as a straight line.
2) We cannot change the style of a fitting or appurt in profile as we can in plan
3) The PP network is not available as a data source when attempting to use the pipe data in a band (as is a gravity network)
4) We cannot control the location of the leader start point when labeling fittings, pipes in plan - also, same 2014 drawing it is different in V2013
Any resolution of these issues would be greatly appreciated.
4 REPLIES 4
Is there a fix for this yet?
After doing a search for issue number one in the list it seems that quite a few people have been experiencing the same issue as I, for a while now, at least a year.  Is there a fix to this other than promoting the shortcut?  Could someone help?  Autodesk are you working on fixing this?  Feedback is appreciated.
JustinErb
This thread http://forums.autodesk.com/t5/autocad-civil-3d-general/c3d-2015-pressure-pipe-follow-surface-and-dat... has a workaround for your issue #1.
Civil 3D 2014 SP2
mconway
in reply to: JustinErb
Due to software limitations, you have to run the CURVEPIPEINPV command in the reference drawing also. It works fine. See the link below.
https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
At your service,
__________________________________________________
Mark A Conway –Director of Design Technology | Gilmore & Associates, Inc.
Autodesk Certified Instructor
AutoCAD Civil 3D Certified Professional
Autodesk Certified BIM Specialist for Roads and Highways
Rail Community
